Question about Lexmark X83 All-In-One InkJet Printer
Paper will not feed through though the carts do pass
WHYFMR6P4WXK
My printer did the same thing, paper would not feed through so my son and i took it all apart and found the feed driver gear to be cracked, "it's a little plastic gear on a long shaft", and it was slipping on the shaft.
To fix it we hard wired the gear together where it was cracked to made it more tight on the shaft.
Unfortunatly by taking it all apart we broke it, now it gives an error message "Carrier stall press power key", havent't found a fix for that yet, but we will :)
Posted on Sep 04, 2008
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
Bypass feed
this is set by the computers driver
or its detecting no paper in the main drawers
Jan 10, 2015 | Toshiba e-Studio 350 Copier
Paper jammed inside my printer near bottom
open front cover where toner cart is situated and remove cart.check and see if the jammed paper has fed into the machine and if so pull paper in the direction it is feeding into the machine.
Oct 26, 2012 | Samsung ML-3051N Laser Printer
Printer prints addresses on paper, not envelopes, even though I click all commands correctly.
make sure you feed in the envelopes correctly and adjust the guides to fit the size of envelope you have in the manual feed or paper tray verses the size of envelope you choose in the print settings from the application you are using (MS-Word) e.t.c, also make sure that envelopes have the correct paper type and design for printing i.e( without metalic clips, not too thick to pass through the fuser)
size 10 is usually easy to go through for example.
Dec 03, 2010 | HP Photosmart C5580 All-In-One InkJet...
Epson 7600pro air in ink line
You can try an Initial Fill of your ink carts. It is the next level after attempting to clean the heads. However, if this only temporarily fixes your problem, you could have a leak in the supply tubes, or the head could have failed.
Turn the epson off. Hold down the buttons [Paper Feed δ]+[Paper Feed ∇]+[Cut/Eject] and turn on the printer. This will take you into a hidden service menu. Hit the [Paper Feed ∇] button until you get to "Cleaning" then hit the [Select] button to enter that submenu. Hit the [Paper Feed ∇] again until you see "Init Fill", and then hit the [enter] button. The display will say "charging". Just wait until it is done, then turn the printer off and back on.
If you do not have enough ink in the in the carts you will be prompted to replace them. The same goes for the maintenance tank. Make sure you put the ink lever back in the lock position if you change the carts. (It will not give you an error about the ink lever being down, it just won't do anything.)
Jan 09, 2009 | Epson Stylus Pro 7600 InkJet Printer
Printer leaving smear marks on paper
Are you using genuine Canon ink carts?? The cheaper "pattern" carts often use lower grade inks that don't dry as quick.
Also try feeding two or three blank sheets through the printer to clean the rollers and guides.
Jan 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Will not feed paper to print
Do a Mr. clean act on all rollers coming in contact with paper. I use distilled alcohol and cotton and it has worked for me.
Sep 06, 2017 | Dell 1700n Laser Printer
Paper twists when feeding
there is something stuck in the feeder.place one thick paper and help it with your hant to pass into feeder.anything is inside will unstuck
Nov 04, 2008 | Epson Stylus Photo 950 InkJet Printer
Paper goes through the printer as though printing but paper comes out blank
Just make sure the cartridges are not running out of ink. Try with different carts, It should work fine.
Apr 20, 2008 | Office Equipment & Supplies
Hello
Did you use generic ink carts? If yes and those have a scotch tape as a seal, ink has splashed and stained the led-control board.
Do use a full brother ink cart and place it into the machine. m
always make sure that the colored latches are secured (clicked into position.
Another chance is that the generic cart is a bit too small. feed some paper BENEATH the cart. Leave some more paper to be pressed by the latches.
Feb 04, 2008 | Office Equipment & Supplies
Lexmark X83 All-In-One InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
