Question about Maytag PAV2300 Top Load Washer
Loud motor noise
Whenever the motor is running - wash and spin - it is now very loud - like an old lawn mower. this is new - used to be pretty quiet. Still runs. Phone-up repairman feared a bad bearing and said to trash the washer.
  • 943 Answers
Hi thanksfor the question before you trash it take a look at the pump pull washer towards you tip back towards the wall look under neath pump is at the back on righjt remove the belt and turn the pump by hand if noisey replace thanks the appliance doc
Posted on Sep 26, 2008
Why does my washer making a VERY loud noise while spinning. So loud you could hardly stay in same room. Ususally its pretty quiet. Then I heard something that sounded like a gear (?) being stripped or
2 possible things. the spinner drum bearings are giving up. This can show as a rusty water dribble under the machine.
The motor bearings are giving up.
Both of which require a good DIYer or an appliance engineer.
Aug 05, 2014 | Maytag Washing Machines
PTO clutch making a loud clicking noise.
I really need some more info from you...but here are a few things you should check? Since it clicks with or without the belt...it has to be an electrical issue! Check the switch, look for broken wiring, or loose connections. Another thing it might cause this is the battery or the charging system! If there is not enough voltage to hold the clutch engaged or what it is getting is shorting out then that would be your culprit! I hope this helps! "Be Easy!" Neighborsboy
May 04, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
My washer is 4 years old and the last couple of times I used it, it made a very loud noise when it was in the spin cycle and now it is more quiet but it is not spinning all the water out.
Welcome to FixYa.
Have you checked the pump to insure nothing is in there causing the noise, or do you believe it is coming from the main wash basket ?
I would rule out anything being in the pump first before declaring the main bearings or motor brushes being worn which can sound pretty loud, but usually just in the spin cycle.
I could possibly assist in directing you "how to" if I had a make and model number, or you can refer to your owners manual and that should have instructions on maintaining and cleaning the pump.
Let me know what you find out.
good luck
macmarkus :)
Jul 29, 2010 | Whirlpool Washing Machines
5.5 Briggs & Stratton push mower running too loud
It could be the govenor spring. Get the model number, type and code and take it to a small engine parts store and get a new one. A new spring will slow down the rpm's and it wont be that loud. Make sure you remember how the spring was hooked up.
Let me know if this helps.
Thanks \
roundo4
Aug 25, 2009 | Garden
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Valve noise
Hi you can set them to 4 thou it should quiet them down pretty much
Jun 14, 2009 | Garden
Very loud noise BUt washes fine
could be wheel on back of drum check its not loose , only way to get to filter is to remove the pump from filter assembly lay it on the soap draw side to get to it easier
Apr 04, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Maytag PAV2300 Top Load Washer Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
