Question about Hoover Vacuums
Hello . The beater bar is not spinning on my Hoover bagless upright rewind. Can I fix this?
  • 31 Answers
Very simple to repair its a broken belt read owners manual or somtimes they print instructions on the head of vaccum belts are sold at walmart you must know make and model or get number of old belt. before buying one check the back where the attachments are some cleaners have spare belts
Posted on Jul 20, 2008
How do I make the noise stop?
Seems like the bearing on the side of the roller has gone bad. If there is a dirt gone deep inside, it is hard to clean it. It can also go bad if the roller hits the uneven surface like the transition strip between carpet and tile. It can unbalance the roller causing it to go off its axis and get misaligned.
This is the roller for the Hoover Elite Rewind
http://www.ezvacuum.com/hoover-93002124-brushroll-for-u5509-u5511-u5512-elite-rewind-p-3607.html
May 20, 2013 | Hoover Elite Rewind Bagless Upright...
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
Hoover beater bar is loud & vibrating.
brush roller /agitator needs replacement. part price : $25.00 to $ 30.00
May 06, 2010 | Hoover U6630-900 WindTunnel Bagless...
Neither the self drive nor the beater bar are spinning
check and see if the belt is broken or if there is something wrapped around the shaft that will keep it from turning... hope this helps...
Apr 03, 2010 | Hoover U6630-900 WindTunnel Bagless...
How do I install a hoover windtunnel vacuum cleaner belt. The bagless one,.
First, take it outside or to the basement. This can get messy. Turn the vacuum cleaner upside down. Remove four 1-1/2" self-tapping screws that hold the bottom cover in place (where the beater bar is.) Remove this and you will see where the belts go; one from the beater bar to a grooved wheel and one from a bowed wheel to a metal spindle way in the back. The beater bar will lift right out. Be sure to clean the threads and pet hair while you're at it.
Mar 28, 2010 | Hoover U6630-900 WindTunnel Bagless...
Brush wont spin, belt is perfect
It sounds like the motor that spins the beater brush is burned out,If it is under a yr old it should be covered by the manufacturer warretee. Find a Hoover service center that does warrentee repairs.
Jan 25, 2010 | Hoover U8188-900 Bagless Upright Vacuum
Hoover Elite Rewind
Something's rubbing. It is probably the beater bar rubbing against the base plate. Remove the base plate and check that your beater bar is back in the sockets of the vacuum frame correctly. If they get installed a bit off, it'll make a LOT of racket. Check it out!
Aug 05, 2009 | Hoover Elite U5061-900 Bagged Upright...
Hoover Elite Rewind - powerhead brushes are not turning
most likely band is broken. Usually there is a spare in the box or on the unit when new. Unscrew 2-3 screws by beater bar (brushes) pull off cover and replace band.
Jul 09, 2009 | Hoover U5507900 Elite Rewind Bagless...
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
