Question about ASUS Computers & Internet
Latest bios update for asus k8n motherboard - ASUS Computers & Internet
    Scholar:
  • 81 Answers
Hi rpeetry,
Following link is a good place to download your bios driver for your computer.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Posted on Jul 20, 2008
I have a K8N-VM mobo. I flashed it up the other day. Initially it worked fine but when I tried to go into the bios settings it hung. I rebooted and got the Bios Checksum error screen. I shut down and...
Reboot, go into the BIOS despite the error message then lower some settings below default values. Save and restart - if you got the same error message again then the BIOS chip is no longer powered correctly, the motherboard is dead.
Aug 25, 2011 | ASUS K8N-VM Motherboard
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
I have an Asus K8N-E motherboard which does not seem to support booting from USB. Any suggestions?
You must configure the BIOS prior to booting up from USB. With the USB inserted, go to the BIOS setup and change the boot priority as explained on the official user's guide from ASUS (page 61):
http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-E/e2164_k8n-e.pdf
Jul 10, 2011 | ASUS K8N-E Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
I need vga driver
Hi, try the following site for your vga driver, you need to scroll down the page to pick your operating system:
http://www.easydriverpro.com/driver-update/motherboard/asus/k8n-dl/k8n-dl-windows-7.html
Oct 05, 2010 | ASUS K8N-DL Motherboard
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
ASUS K8N MB On board audio doesn't work. I've verified that correct settings in BIOS but signal is not making it to the plug for Line Out. I just installed SP2 so I'm going after new drivers next. Any...
Check FP_AUDIO pin settings. FP_AUDIO is located just below the CD AUX. See page 1-6, Motherboard layout.
There should be a jumper over pins 9 and 10 and pins 5 and 6. This is the default setting chassis rear MB audio output.
See page 1-22.
Unfortunately the audio chip is soldered to the motherboard. Most newer Asus MBs the audio chip is not soldered and can be replaced by calling Asus.
Asus manual; http://dlsvr04.asus.com/pub/ASUS/mb/sock754/K8N/e1868_k8n.pdf
Link to Asus site, K8N; http://www.asus.com/product.aspx?P_ID=zigzffr75jWJ7j2y&templete=2
A possible work around would be to disiable the AC'97 in the bios and add a PCI audio card.
Cheers'
Mike
Feb 04, 2010 | ASUS K8N Motherboard
I F disced my computer recently and now am trying to set it up again. Where can i find drivers to install my ASUS k8n-e socket 754 motherboard online?
Try this download site:
http://drivers.softpedia.com/get/BIOS/Asus/Asus-K8N-E-Bios-0411.shtml
click on the download button, select one of the "external mirror" links, and it should begin to download the driver for it.
Aug 08, 2008 | Computers & Internet
K8n-lr motherboard
1 long beep and 2 shorts beeps indicates a problem with your RAM. If you have more than one RAM chip, remove one of them to rule out a faulty chip. If you only have one chip, remove and reseat it. For clarity, you can find the manual for your board at; http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8N-LR And the Asus general motherboard troubleshooting manual at; http://support.asus.com/images/document/ts/E2437_MB.zip
May 30, 2008 | ASUS K8N-LR Motherboard
K8N motherboard
Have you tried a secondary PSU? (though it sounds like your motherboard needs replacing)
May 23, 2008 | ASUS K8N Motherboard
Computers & Internet Logo
71 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
