Question about Philips 9FF2M4 9" Digital Picture Frame, Digital Photo Viewer
Copy photos from pc
I have installed Photo Manager software and previously copied pictures to Photo Frame. It appears that the link between Frame and PC is not connecting.
The photoframe side is blank and pictures on the pc will not drag to the photoframe.
How can I check the connection or otherwise correct the problem?
jnmpat737@cox.net
  • crinkler Aug 19, 2008
    The photo manager installs but pictures will not transfer from one side to the other,fromcomputor to frame.
  • crinkler Aug 21, 2008
    Still no go I'm afraid. Everthing installs but it fails to paste.Pasting graphic flashes up breifly then disapears and nothing happens.
    Crinkler
  • 96 Answers
Look for an option when you open photo manager that says upload picture. Browse the locations then choose my computer, pictuers and click open the picture that you want in photo manager. Other wise, try to put/copy the picture in a new folder in you computer, then click cut and paste to photo manager.
Artgirl
Posted on Jul 20, 2008
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How do i copy pictures from camera to frame with a usb connection
it's easy, if you allready have installed the software camera, u just have to save your pictures in a folder and after this, you can with a right click on the picture you want to copy, select copy and paste in the same folder or paste in another folder.
Aug 05, 2011 | Aluratek 12-inch Hi-Res Digital Photo...
Cannot enter more pictures
Some models allow you to set photo copy or import method to "optimized". This will compress the photos as they are copied to the frame and allow you to fit more on it. But in order to use this feature, you must copy from a memory card or USB drive, not a PC. A PC will override the copy mode.
Aug 05, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Can't transfer photos from computer to digital frame
1. Install EasyShare software (free download at www.kodak.com/go/sw)
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
I'm trying to transfer pictures from my computer to the picture f
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Omnitech 8.5 Digital Photo frame...no Instructions
I had this same problem and after playing with it for several hours, I discoverd the software that came with the frame was copying my photos to the "D" drive. Since my frame was connected to my computer through the "g" USB, of course the photos were never copied. So I went the the Smartparts software (that came with the frame) and found the folder which was saved on the "d' drive. I then did a simple "copy to" "g" drive (this is where my frame was connected to. If these instructions are clear, ask again and I will try to further help you. Good Luck!
Dec 18, 2008 | Coby DP-888 8-Inch Digital Photo Frame...
Transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  4. In the menu bar, select File ® Copy to.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Dec 16, 2008 | Kodak EasyShare EX1011 Digital Picture...
Have a kodak ex811 digital frame
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Once you connected your EX811 to your computer, and get the message “Use PC interface to copy files.” That means you can start copying files. Here are the steps:
Oct 27, 2008 | Coby DP-888 8-Inch Digital Photo Frame...
Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Jun 20, 2008 | Audio Players & Recorders
Philips 9FF2M4 9" Digital Picture Frame, Digital Photo Viewer Logo
318 people viewed this question
Top Philips Cameras Experts
Lyle Siemens
Lyle Siemens
Mohamed Ismail
Mohamed Ismail
Prashant Hattangadi
Level 1 Expert
Are you a Philips Camera Expert? Answer questions, earn points and help others
