Question about Olympus VN-3100PC Digital Voice Recorder
"chk" error on screen olympus vn-4100 pc
I got a "chk" error code blinking on the screen. what should i do to be able to use the recorder again ? txs
  • 3 more comments
  • dolfinen Aug 12, 2008
    Just bought this Olympus Recorder VN 4100 2 days ago, used it for immensely important interview. Now all I get is Chk message and no response other than that. Have tried installing the software to PC, it makes no difference.I have no clue if the data i stored, but I checked just after the interview and it was there. What a lousy product.
  • caroline435 Sep 07, 2008
  • lucky_009_ Sep 22, 2008
    chk button will not go away or allow me to do anything.... a bit annoying
  • Anonymous Dec 29, 2008
    sames issue chk fllashes, then err
  • tijgertje Mar 26, 2009
    ERR on screen, does not do anything any more
  • 5 Answers
I had a similar sounding problem my Olympus VN-5000. I would turn it on, it would show "CHK" for a few seconds, and then "ERR." This persisted despite fresh batteries. The "ERR" message reportedly means a memory error. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model...
Posted on Dec 31, 2009
Something to add to the above solution:
6: When I tried this, I had to leave the recorder plugged in for several minutes before it reverted from CHK to PC, but it did eventually fix itself.
Posted on Feb 12, 2009
This is a tricky problem but I finally took care of it.
1. Ditch your old batteries.
2. Get new batteries. Do not replace the batteries yet.
3. Connect your recorder to your PC with Wave Recorder installed. The message should change from "CHK" to "PC".
4. Put new batteries in the device.
5. Hurray, you're done !
Posted on Jan 09, 2009
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Make sure recorder is off hold
Posted on Aug 20, 2008
My mac os x does not detect my olympus vn 4100 pc digital voice recorder.thanks
According to Olympus the VN-4100PC is not compatible with the Mac.
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1291&os=m
Jul 08, 2011 | Olympus VN-4100PC Digital Voice Recorder
Display screen flashes "CHK" repeatedly
Hello.
From FixYa Support: The "ERR" message reportedly means a memory error.
Please NOTE: This solution will wipe out the memory.
Press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again.
Hope this helps.
Apr 03, 2010 | Olympus VN-3100PC Digital Voice Recorder
My Olympus VN-3100 voice recorder has suddenly stopped working! When I switch it on it flashes CHK for a couple of minutes then says ERR
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory (ERR means memory error). Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model.
Dec 16, 2009 | Olympus VN-3100PC Digital Voice Recorder
Digital Voice Recorder Olympus VN 4100 PC
I found software available on an international olympus website. I was able to specify my operating system and my digital voice recorder model (VN-4100 PC) and voila, it gave me the download link for the full version software (not just an update).
I haven't actually installed it yet, so I don't know if it works but here is the link to the website: http://www.olympus-europa.com/consumer/2590_software.cfm?category=8&productgroup=347&product=&os=7&result=
Sep 13, 2008 | Olympus VN-4100PC Digital Voice Recorder
Locked up
Check your battery polarity. Unlike most devices on the market, the Olympus recorders have both their batteries pointing the same direction. Normally the positive end of the battery points toward the bottom. Look inside the batter compartment for the correct polarity.
Oct 14, 2017 | Olympus VN-4100PC Digital Voice Recorder
Olympus VN-3100PC Voice Recorder Problem
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in all the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again. Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
Jun 25, 2008 | Olympus VN-240 Digital Voice Recorder
Error message
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again. I hope this solution works for your model!
May 26, 2008 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-3100PC Digital Voice Recorder Logo
4,147 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
