Question about Motorola Mobility RAZR V3i Cellular Phone
Reception loss i cant get reception.were does the antenna go inside the phone
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile shop and have them assist you with that
Posted on Aug 09, 2008
The FM radio reception went out. AM radio reception is still ok. What should I look for to fix the loss of FM radio reception?
Pull radio and check antenna plug in rear of radio, They'll still pull AM with antenna unplugged
Apr 03, 2011 | 2005 Chrysler 300
My phone keeps saying its searching for service when im at home and i have always had service in my home. What should I do?
It is possible that the phone has dropped in its reception due to some issues in the antennae section. If you are able to work when you are out of the house then it is for sure that the low reception of the nearest tower is down. First of all check with your service provider if the tower is having an issue some times it may be operating in less power- a possible down condition. IF not check your SIM with another phone, if the signals look ggood then you may need to open your set to check if there is any traces of moisture , break or coneecction loss in the antennae output section. Look carefully clean and set back. If not the phone network IC may be defective/weak. Hope this works out. Good day
Aug 15, 2010 | Samsung Gravity SGH-T459 Cell Phone
Will I get good reception in a metal factory building I get spotty fm reception with my current radio
With old radios it worked to connect the antenna to some central radiator or (metallic) water pipe. Some old wire was used to connect it;
Feb 22, 2010 | Grundig S350 AM/FM/SW Radio
FM/AM reception problem
It should- that splitter is generally used for factory telephone reception and also there is an antenna located in the rear window glass. It will work for radio reception but it will interfer with your phone if you have a phone installed. just make sure you have a good antenna ground. Try removing the grond and sanding the metal so that there is no paint or oxidation that causes higher resistance. This generally affects a.m. reception.
Jul 17, 2009 | 1998 Mercedes-Benz S-Class
I-mate Jama 101 Reception problem
Hello. I boght one of this but at home I had no reception. I had to take out the camera because I cannot use a camera at work and I tried something I had done with my previous phone. there is an external antenna conector. I take a piece of thin insulated wire ( as the one used on fixed phones) peal off about 3 mm and inserted it into the cell phone's external antenna, route the wire inside phone and close it carefully. For my cell it really worked. Now I have 50% signal at home and 100% on the street.
hope it work : )
May 20, 2009 | i-mate Jama 101 Smartphone
Cell phone reception dead after using amplifier
I had this same problem with a motorola razr some time back. Some cell phones have a built in switch (such as the Razr) inside the external antenna connection. In the case with my razr, I
evidently pushed the adapter into the phone too far. I later had to jump out the switch inside the
phone to make it work with it's internal antenna again. Unfortunately, I could'nt use that same phone with my amp again. Just a thought on your problem.
Dec 01, 2008 | Wilson Electronics 811102 Direct Connect...
Distance of reception
Oh yeah. The best radio to get reach that distance with no problem would be a 10 meter, such as a General Lee, Connex, Stryker, or Galaxy with a 2 digit model number. Those, with a good antenna set up properly, will reach out 10 miles real clear and up to 14 - 15 miles with some reception loss.
Regular cb radios, such as Cobra, Galaxy 3 digit model numbers, Uniden, etc will have a decent reception, but generally when used barefoot, will only transmit and recieve about 6 miles real clear and up to 9 or 10 miles with a decent amount of signal loss.
Now, you do not have to have a big, expensive antenna to get the distance you want, you can do it with just a cheaper fiberglass stick antenna like a Francis 4 1/2 foot. After I installed a Francis antenna and a General Lee on a tuck outfited the other day, I was able to talk to a man apx 14 miles from my location.
The main thing to look for when installing the antenna is that you have a good coax (braided center conducto and 95% braided sheilding), and that the antenna is not grounded out, just the bracket (this is what makes your ground plane). Make sure the nylon spacer (looks like a plastic washer with a lip on it) is place on top of the antenna mount, with the lip facing down through the hole. You can use a magnet mount antenna, but you will have much much better luck with a hard mounted antenna.
If you have more questions, or if you need me to send a picture showing the placement of the antenna and bracket parts, dont hesitate to email me. rollincbmoew@yahoo.com
Dean Pitts
Rollin CBs
Aug 28, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
I bought a 32" conia tv and i cant get good reception! i have bought a amplified antenna and a hd set top box and still no good reception. my other tv's in the smae spot have had no reception issues....
well it's the same as the days of old, the antenna has a range of reception. the further the sations antenna, the lager your antenna must be. just because you bought an amplified antenna does not mean you will receive the deep fringe station. also the antenna must be UHF and VHF to receive the broadcast in digital. most of the braodcasters have gone with the UHF band because it is more stable for the bandwith of digital broadcast. the UHF band is very directional as well, so you must be pointing to the broadcasters antenna. no set top antenna will work if you are further than 15 miles of the broadcasters antenna. the roof top UHF/VHF antenna with a preamp is the way to go. I have tested every compact antenna and unless you live in the city that the broadcast generates you will get no reception with these. terks are junk, and any small amplified antenna does not work if you are in low lying areas. roof top, roof top,.....ROOF TOP!!!!!
Apr 24, 2008 | Televison & Video
Razr V# lost service after using external antenna
I have the same problem. Contacted 3rd party tech, take sharp pick or equal and there is supposedly a button in the very center of the antenna port of the phone. gently push the pick in the center of the jack and it will trip the switch. I tried it on my second damaged phone and it worked, so far.
Nov 24, 2007 | Motorola Mobility RAZR V3
W300i(Aust.) loss of antennae signal
try an antenna booster see if that helps
Nov 21, 2007 | Sony Ericsson W300 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
26 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
