Question about Dometic Rooftop RV Air Conditioner
5th Wheel A/C Unit Freeizes up
Runs for a couple of hours then freeizes. Have cleaned filter and run on high fan. Any suggestions?
Thanks Mike
  • daiglekg Jan 29, 2009
    Same problem for me. Runs and blows cold air for an hour or so and freezes up then the unit boggs down with very little air blowing into the RV. Mine is a Duo Therm 15k Quik Cool roof top A/C and is 3 years old. Changed out my T/S earlier becuase it was "short cylcling". That seems to have went away. Cleaned coils but still freezing up.
  • Dometic Master
  • 6,674 Answers
How old is the unit ? Model ? Did it work fine before?
Posted on Aug 15, 2008
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
Hi,Ice on the suction and discharge line in LG split a/c. Please help me to clear this issue. Thanks.
Check and clean condenser coils with good coil cleaner
Put exterior fan on it to veify it.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 22, 2010 | Goodman CKL30AR30 Air Conditioner
Ckl60-1l outside fan runs good,compressor do not run
Reasons for icing up are dirty filters,dirty indoor evap coil or low on refrigerant. Check these. Your compressor is probably overheated. Let it go for a couple of hours if you are in a hurry. Run a water hose over it. Rus
Jul 15, 2009 | Goodman CKL60AR60 Air Conditioner
Fifth wheel A/C PROB
Most probably your unit has no more refrigerant charge. Being unused for 8 yrs will cause leaks on seals.Locate for the system sight glass, run your a/c,if you don't notice any bubbles nor liquid appear on the sight glass your unit runs out of refrigerant.Hope some of this information helps you.
Sep 11, 2008 | Dometic Rooftop RV Air Conditioner
My unit works fine in temperture of high 80s. Anything above that it runs constantly for 5 to 7 hours. I do not remenber it doing this last summer.
Couple or reasons, Unit sized too small, plugged filter or low refrigerant. Have the unit cleaned and inspected by a qualified technician.
Jul 27, 2008 | Heating & Cooling
LG LD65EL Dehumidifier doesn't work properly
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
Jul 02, 2008 | LG LD65EL Dehumidifier
I purchased a 1994 5th wheel with a Coleman air conditioner. It had been covered and in storage for 3 years. When I turn on the thermostat, it sounds like its trying to work but quits after a minute or...
You may have a power supply problem. If you are connected to an external power supply with a cord, make sure it is able to carry the necessary power. To small a cord will cause a voltage drop giving insufficient voltage to run the compressor. The noise you hear is the refrigerant pressure equalizing in the system after the compressor shuts down.
May 09, 2008 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
57 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
