I have fust got a new dvd burner {LiteOn 20x /- Ram & DL Black DVD Writer Rewriter} after installing it .i rebooted the computer ,bur it wont come on .i took the writer back out and the computer fired up ok again. do i need a driver for this writer please
    President:
  • 1,314 Answers
No but it sounds like your burner is DOA. Take it back and exchange it.
Posted on Jul 20, 2008
My multi dvd writer door opens every time I insert a disk it opens by itself
Check for loose contact, dry solder at the power connector end, try cleaning the lens, most of the times the rubber belt that is used to drive the tray gets loosened due to time factor and usage
Jul 29, 2010 | Lite On LiteOn LH-20A1P - Disk drive -...
I intalled model iHAS324-32 Y to replace iHDS 11807-4 and vista wont run with it. Tells me to uninstall it and contact manufacturer. I uninstalled it and system works fine again without the disc drive.
Is your vista a 64 bit OS? If so this dvd-writer is compatible with 32 bit OS. You may need to upgrade the firmware for it. Maybe this link can help LiteOn firmware search.
I've upgraded firmware for a dvd writer already with no bad consequences but I have crashed one of my motherboards trying to do the same. So if you're not comfortable doing it, get the people you bought it from or some techie to do it for you. Hope this helps
Dec 22, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Write error message with liteon dvd writer..
I had the same issue with a liteon DVD drive I had. It worked fine and then one day it couldn't write to a DVD if I paid it to. I troubleshooted it for a few days, installed all the latest updates and patches and still nothing. From what I could tell, it baiscally died. So fortunately Liteons are relatively cheap so I just went out and got another LiteOn and it worked just fine. I would consider purchasing a new Drive.
May 04, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Not recognized
Go into your BIOS and see if you can get it to autodetect the drive. You should be able to this but I can't tell you how to because all BIOS setups are different.
Then save your BIOS and reboot.
The drive should then be recognised as the right thing.
Hope this helps
Mowcius
May 16, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
LOST INSTALATION DISK
Hi, check here and you will find the drivers you need for your dvdrw. Thanks! /D
http://www.nodevice.com/driver/company/LiteOn.html
Apr 27, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
System cannot see lightscribe drive
try to update the firmware of that drive. then try to go to device manager to see if there are any changes.
Mar 23, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Liteon DVD writer & re writer
You can not use cable select without the correct cable. Most "stock" cables are not. So...
An IDE port supports -2- drives (CD, HD, DVD, Etc). If you have 2 drive connected on the ribbon cable then one must be set to master and the other to slave (the little jumper clips on the back). If it's the only drive on that cable, set it to master. Some drive may say Master Only and Master with a slave.
Geno
Feb 16, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Can't burn I-Tunes downloads to CD on my new rewriter
the retailer is correct, you can only play the tunes that you have downloaded on the one pc and an ipod because of the licenses that are downloaded with the songs.
Oct 25, 2007 | Lite On LiteOn LH-20A1P - Disk drive -...
Cd audio can hear but no dvd audio
First check that the 'Wave' slider in the volume control is not too low or muted.
Check in the DVD player software that you have the correct DVD audio stream selected.
Then suspect the audio codec that should have been installed with the DVD player software.
Oct 21, 2007 | Lite On LiteOn LH-20A1P - Disk drive -...
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
