If you are plugged into a 10 amp circuit or if the line from the circuit breaker to the outlet is long or 14 guage wire, it could possibly still be the outlet. Try plugging the compressor in to an outlet closer to the circuit box to see if the problem persists.
On the compressor the only thing that would create problems like you're describing is excessive friction in the moving parts. Check where two parts that move together are not doing so without excessive wear or heat. Check to see if the motor is turning freely, the eccentric to connecting rod joint should be free moving and smooth and the piston in the cylinder should be tight but smoothly operating.
