Question about Bose LifeStyle 5 Series-III CD Shelf System
Bose Lifestyle model 5 .....no sound
Console turns on and the CD plays, but no sound. I do get output via the headphone. No sound thru the sub. Do you have a fix......thx
  • boseDing Feb 23, 2009
    Same problem (almost), turned on the system, the speakers played normally for about 1-2 seconds, then gone, the unit still works through the headphone jack.
SOURCE: Bose lifestyle model 5 /Acoustimass 25 sub power problem
Open or leaking components will look OK but, may not function as designed. Rather than create more problems, please consider whether the unit is worth repairing by a pro/tech, if so, do so.
Posted on May 10, 2008
  • 12 Answers
SOURCE: No sound Lifestyle 5
Hi the problem could be a burnt out R428 resistor replace with a 330 ohm
Dave
Posted on Oct 14, 2008
Have you try plugging in the power cord.. Switch off the power cord.
Posted on Jun 04, 2009
cjackHD
  • 71 Answers
SOURCE: Our Bose lifestyle 5 has no sound does the Bose CD
This can be repaired of it's later than a series 1. (not sure if the 1997 model was a series 1) Repair cost will be $225 plus tax (flat rate). Shipping is split between you and Bose. They give you a new 1 year warranty.
Otherwise, Bose can have you trade this in for about 25% off a new, current system.
-If this still powers up, make sure the small 1/8" portion of the input cable (plugged into "system control 1") is in good condition, because you may just need to replace that input cable for a no audio situation. If it's a different series, it will say "zone 1" I think.
In either case, you should call Bose tech support about this. (800-367-4008) Make sure you're with your system so they know what series of LS5 this is.
Posted on Jul 17, 2009
  • 5 Answers
SOURCE: ive got bose lifestyle model 5 system and have
There should be an AUDIO OUT left and right rca input/output plugs on the back of te TV; according to this, (http://www.bose.co.uk/GB/images/Lifestyle%205%20Series%20II%20Music%20System_tcm6-4083.pdf) the inputs for the audio are right next to the FM antenna port/plug so, if you have one of these; (http://www.inmax.ca/images/rca-cable.gif) just plug them in to the AUDIO OUT on your TV, and into the INPUT on your Bose system.
Posted on Aug 12, 2009
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Problem with Airport express to BOSE Lifestyle
When i play the radio on my bose lifestyle , my radio sounds good. but when i send music with from my apple computer to . airport, and then to my bose lifestyle, the sound just come out from on 1 speaker. not the toher ones, but when i play radio all 5 works....
anybody got a solution??
Alex, Sthlm
Jan 20, 2010 | Apple AirPort Express with Air Tunes
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Nov 26, 2008 | Bose Lifestyle 38 System
No sound
Hi the problem is R428 open circuit, replace with 330 ohm resistor
Dave
Oct 12, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Lifestyle 5
Hi, it could be R428 open circuit replace with 330 ohm resistor
Dave
Sep 01, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Dave
May 12, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
No sound
Do you have sound from the headphone outlet? If yes, then it could be a known problem on the model 5 where it will not switch on the sub.. I have a fix for this, just let me know.
Apr 02, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose LifeStyle 5 Series-III CD Shelf System Logo
205 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
