After 4 to 5 months, camera when powered on, will not function with any of the other electronic components, not matter what you try; zooming in, pressing menu function, snapping a photo. Lens simply remains open with no functionality beyond that. The only way to power off, is to open the battery compartment. What is wrong with the camera? Do you think Nikon will back this problem up by either fixing the internal electronics or replacing it? Any advice would be greatly appreciated.
SMPS(Switching Mode Power Supply) is a device which converts commercial power into high-efficient/high quality power necessary for all sorts of electrical appliances, with using the switching of a semiconductor component and the power conversion function of a transformer.
It consists of electronic components such as a semiconductor component, a transformer, an electrolytic condenser, a passive component, an injection molded part/apparatus, etc.
Here is a few tips to look for in a good surge protector:
1. Response time should be less than 1 nanosecond.
2. Energy absorption/dissipation should be at a rating of 600 joules or more.
3. Clamping voltage should be 330 V to 400 V. Generally, a clamping voltage more than 400 V is too high.
4. Get one with a an indicator light that tells you if the protection components are functioning. All MOVs (Metal oxide varistors (MOV) are semiconductors that protect electronic components and systems from transient voltages) will burn out after repeated power surges, but the protector will still function as a power strip. Without an indicator light, you have no way of knowing if your protector is still functioning properly.
5. Get one that has self test function. A button you push to test it.
The resourcefulness of the camera is what achieves the experience. Usually an already acquired camera least malfunctioning is within user experiences. The camera would require component devices mentionable as replaceable or delectable batteries. Also occasionally, the depleted resources may require restorations mentionable as power charging or discarding to acquire from alternate location to recapture feature functions. The cameras details are acquirable from owner's user guide or observing devices feature functions to ascertain what is comprised. Power batteries for the camera comprise of several capacities. Prior to requesting from retail, ascertain the most compatible battery required by device either from owners use guide, or inspecting the battery compartment for written details as brands, cell capacities. Also, camera batteries may provide suitable power supply capable of several brands. Usually advisable to acquire the brand most prescribed suitable for the camera. Significant notes includes acquiring batteries that make the camera achieve as much productivity. Unless those Panasonic batteries were the prescribed version for the device, it may be most suitable as high capacity currency supply. Several batteries perform similar functions of capacity requirements also available in feature compatibilities for camera. Mentionable examples are Duracell, energizer and ever ready brands. Camera devices are general making possible several means to resort. For example, a camera may least malfunction but require acquisition of new devices to attain feature effects least available on the old device. Prior to visiting the electronic retail either on the networks or at store locations, inspect the device to make possible acquire another device in place that would have feature functions least present. Camera inspection observations include innovations of motion pictures, user friendly features, multifunction features, also technical features includes pixel quality, adjustable lenses, only mentionable with innovated cameras.
The battery must have run down over prolonged storage. It mayhave been stored while still on causing battery shortage. First attempt to power charge for full extent to ascertain if the camera is is in functioning order. Any unobservable faults thereafter equates to usually functionality. goodluck
Once the camera is powered on for the first time, the system performs an inspection of the regular functionalities of each components. The lense usually may not be requried for every shoot only requires text at powering on. Second the camera requires a test shoot to ascertain that a malfunction may not have occured. Once acquired normal function, perform battery full charge as may have been the situation with least bettery current is unable to power the camera and lense altogether.
One view point is that "Electrical" relates to the development and delivery of the electrical energy to the various devices that perform specific functions in a given environment. Example: The alternator in your car that series of wires delivers electrical power / energy to various components (radio, the computer that monitors / controls operation of the engine) in todays cars.
Where as "Electronics" relates more to the complex functions performed within a given device, more often now days by circuits comprised of many micro electronic sub components that make up the structure of a single micro electronic component. Example: a typical CPU chip would / could contain thousands of individual transistor circuits within a device no bigger that the size of your small finger nail with room to spare. GOODLUCK
Some of these fixtures have a function built in that turns the light on solid if the power is cycled rapidly several times. If you have had power glitches and this unit has that function, it might be locked on.
Pull the circuit breaker for the light for a couple minutes then try re-powering it to reset the function.
Hi, You may be able to recover the camera to previous functionality if you disassemble the camera and clean the PCB's (printed circuit boards) of dew/water staining. Spray the lens with WD-40 to stop it seizing and put the rest of the components in dry warm place for a couple of days so they can dry out. Reassemble the camera and try to power it up.
the best help u can get is from the service center of the camera. else do one thing. as am from india i dont know what place is the HUB to buy any kind of electronics items near your place. if u go to that kind of place where all kinds of electronics goods like computers, digicams, electronic components, etc etc... there they would take the power button from any other old camera and fix it in yours. but one thing is u dont need to prefer for a new button. old one will work fine. even inn service center they have old buttons. so try in service center first. then try in shops.
dear smilemaker - thank you for the suggestions. It took a few more tries than I thought, but that seemed to work.
thank you once again for your help.
