Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KV36HS500 won't turn on
We have had this tv repaired for the same thing a couple of years ago. The same repair man came back out, took the "insides" for about 3 months, brought it back unrepairable. After reading on here, I think it can be fixed. The problem is, the stand by light only flashes 3 times when I try to turn it on? Not like before, when it would flash 7 times take a break then flash again. I have read it could be the power supply circuit. Any help you can lend I am truly thankful!
Thanks
Hallam5
  • 2 more comments
  • hallamhill Jul 20, 2008
    Thanks for the quick response, I have the back of the tv off, where would I find the DZ board? I see the D board would it be located on that board? Thanks again. Ginny
  • kevink52 Sep 28, 2008
    I am having the same problem. Once in awhile it would turn on but not at all now. The standby light flashes 7 times when i try to turn it on and nothing happens. In the book it says it needs to be serviced and i was wondering if it is something i can do. I also wonder if it would be worth fixing it or cheaper to buy a new tv. thanks for the help K2
  • king_luv2006 Sep 29, 2008
    my tv does not turn on, it makes the sound like if it is going to, but it does'nt. the stand by light, flashes six tmmes.
  • fleonard53 Oct 16, 2008
    I have a sony kv36hs500 and it also flashes 7 times, replaced the flyback and the 2 mcz30001d ic's. still the same problem .. does anyone know what the series of caps that should be changed on the "D" pcb are? what are their locations.... many thanks
    frank fleonard53@yahoo.com
  • 10,594 Answers
3 times blinks shows problem of failure of IC6505 in DZ board. If you know basic electronics, open the back cover of tv and go ahead.
Posted on Jul 20, 2008
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
SONY KV-36HS500 will not turn on. Stand-by mode blinks 6 times then repeats. Repair man checked out our phone system earlier today for signal loss and put 500 V generator on phone line to house to check...
the light blinking six times indicates a probable horizontal circuit failure usually a shorted horiz out transistors but this is not the only component located in this circuit that could create this problem, sorry but i am affraid you'll need to get a tech to diagnose it to the component level or get another pc board to repair it. hope this helps some.
Aug 12, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Im looking for a panel for a viewsonic flatscreet tv .
Good morning! what is the part description / number / specifications? Or you can try to look for www.ebay.com for possible supplier/s of the part you need. best regards
May 12, 2009 | ViewSonic VA721 17" LCD Monitor
Tv turns off and on
The first time my lamp needed replaced, the red light came on as well. This time my tv did the same thing, but after talking to my tv repair man he thought it was the lamp. He said that if you use your tv often then the lamp probaly needs to be changed after two or three years. I replacedmy bulb and it corrected the problem and I MUCH BETTER PICTURE.
Dec 29, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sonn tv
There is a very common problem in yur set that will cause this. The KV36hs500 is knowen for two IC's to cause intermitant power condition. A good repair shop will run you somewhere between $300-$400 to do the repair.
Oct 28, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony FD Trinitron WEGA Won't Turn On
The key here is the count of the blinks. I'm assuming that the model number is KV-36FS120. Please post the blink count. It should be a count-pause-count...
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV Powered Off, won't come back on
mine did the same thing, I took it to a TV repair store and they said it was a power surge which damaged the power source board. (possibly caused by lightening)
total cost to repair was $70.00 well worth since was only couple years old.
TV is working well.------we'll see for how long????
Jan 06, 2008 | Emerson EWF2704 TV
Overpoewering red
Every person I know who purchased this very expensive unit has had this problem early in the life of the TV. Sony is no help. Sony will suggest you take it to a repair facility. Sony from years ago is not the Sony of today. It was expensive to purchase and it will gouge you with repairs. Your choice. I eventually discarded my set and purchased a JVC. These rear projection TV's are garbage and Sony knows it and they dont care. Seems like the last for only a few years and then major problems occur. My solution replace it!
May 15, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KV-32S40 32" TV problem
intermittent problems can usuall be liked to bad solder connections. And sony typically has some that will develop after a few years in the power supply. so check for bad sodler connections throught the main board & give a close look to the power supply & check you work after to make sure you have no shorted pins. good luck.
Dec 27, 2006 | Sony KV-32S40 32" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
337 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
