Question about Panasonic SC-HT700 System
Can't adjust color
When playing a DVD the picture is green. I have the manual and have been trying to figure out how to adjust the color but I am getting no where fast. When playing the TV, the color is fine . Is it me, or the DVD?
  • 10,594 Answers
Its connection combination problem of " component video " You have selected/ connected wrong pins with other unit. Always insert same color pin on both unit (TV & DVD player)
Have nice day!
Posted on Jul 20, 2008
The picture colour of my set is a mixture of blue,red & green. how do i set the color ? please help
try to adjust in color set up menu, if can not get with manual adjustment the problem it could be the convergence ic is defective or an open resistor.
Aug 03, 2012 | Televison & Video
Incorrect color when playing DVD
Hello Mustang Cathy,
You have connection problem in Video with TV & Home Theater. This error comes mostly wrong combination of "Component Video" connections. Kindly check that one color pin must be connected with same color pin at other unit. Here is 2 pictures for further assistance. Hope problem will be solved and you will enjoy true color picture on tv.
Apr 07, 2008 | Panasonic TC-32LX60 32 in. LCD Television
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Dvd picture
Make sure component cables match colors between Television and DVD player. It should be TV input to DVD output. Try to play at least two DVDs to make sure its not a single DVD that may be having an issue. Also, adjust your television's picture setting to make sure its set to normal. Also access your DVD players menu to make sure the setting are set to normal as well.If it doesn't correct the problem, use a different component input on your television. If problem persists, you may need to contact the DVD player manufacturer to see if its still under warranty and not defective. Good Luck.
Oct 18, 2008 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Color problem
CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
Dec 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
COLOR
Are you using the component inputs from the DVD player (blue, green, red)? HDMI? If using the component cable, it sounds like one is in the wrong slot. If using HDMI, try looking at the setup in the DVD menu to make sure it is using the correct output. I had a samsung DVD player that kept trying to use the component output even though I told it to use the HDMI and my picture looked red. Let me know.
Jul 31, 2007 | Olevia LT27HVX 27 in. LCD Television
Panasonic SC-HT700 System Logo
115 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
