Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
Have picture no sound
Have Philips 51PW9363n51" RP TV
Has pic but no sound - does not accept remote control codes. Can only operate from front panel on TV - no sound.
Could this be a fuse or something related to the remote control reciever?
Please help....
  • brex50 Apr 23, 2009
    no sound control from remote
  • Philips Master
  • 3,459 Answers
The most likely cause on your model is the HVG. Check the site www.TvRepairKits.com for a kit.
Posted on May 07, 2009
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
How to manually change brightness on a philips 42pfl5405H TV ?
If there is a 'Menu' button at the TV panel, you can select the picture setting, and can adjust the parameters there. Brightness, Contrast, Sharpness etc:
If there is no such button on the TV panel, you should have its remote control to proceed.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Or type in the brand name of your device in the search box, and press "Enter".
Universal remote controls are available at most of the electronic spare part selling shops.
Jun 17, 2014 | Philips Televison & Video
Toshiba MD9DM1 remote code
Codes to check with Toshiba T with Philips universal remote control are:
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Switch OFF and switch ON the TV set, by its front panel power button, and wait to siwch off the standby LED, before trying each code.
Apr 25, 2012 | Televison & Video
Remote works tv part doesnt
Hello
If you are sure about the proper working of the remote, and TV doesn't accept it, the fault is with the remote sensor inside your tV. It can be located just behind the remote sense window at the front panel of your Tv. It will be a three terminal component, will be in brownish black in colour.
gopakumarg43_92.jpggopakumarg43_93.jpg Just see the picture of it. It will be directly soldered either to the front panel PCB or will be at the main board itself. Just locate it. If you have a concept of desoldering and soldering you can do it yourself at home. It is not a skilled work indeed. Only three solder terminals are to be desoldered and resoldered.
The component will have a number printed on its body, normally on the side rim. It must be noted, and the exact numbered component should be replaced; especially for Philips. It can be bought from most of the electronic spare part shops at your town. OK.
Oct 31, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
Need the code for a sanyo tv to use a philips universal remote
Hello
Universal remote code to be cheked with Philips CL034 model remote habset to Sanyo are;
0506 0311 0612 0002
0428 0802 0412 0619
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
NB: Switch OFF and switch ON your TV with its front panel power control switch each time before trying an other code.
OK.
Feb 16, 2011 | Philips Televison & Video
I have lost the manual for my Crest model Po5094-2 remote. I need the code for Philips model 29PT468A TV. Can you please help?
Hello
four digit remote codes for Philips are:-
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Four digit remote code for Magnavox are:-
PHILIPS-MAGNAVOX ..... 0062 0204 0207 0183 0226 0288
Three digit remote codes for Philips are:-
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
Three digit remote codes for Magnavox are:-
PHILIPS/MAGNAVOX Codes: 183/ 184/ 208/ 213
NB: Switch OFF and switch On the tv with its front panel power switch each time before gointg to an other code.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Ok
Jan 15, 2011 | Philips Universal PH301S Remote Control
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
My 32in sdtv red power light,no pic no sound
your problem is likely to be in horizontal section of tv. please take the help of skilled tech. it is not a major problem but as you know that it is a high voltage device.
Oct 05, 2007 | RCA 32F531T 32" TV
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
