Question about Linksys BTOPENWORLD / WIRELESS UPGRADE 1 X USB ADAPTOR (WUSB1110402A) Modem
D link usb adaptor
Hope you can help.
I have purchased a dlink usb adaptor revision c which will not link to my computer. I have a 6 year old standard computer with XP and updated to present with no fancy additions.
I have used the bundled disk and tried the online driver which have the same results. When the driver asks me to plug in the adaptor it is not recognised (I have tried several usb ports which all work with other stuff). The windows hardware wizard (which the driver says ignore and cancel, but this might be relevant) notices the adaptor, recognises it as dlink etc when driver installed, and 802.11 something or other when not, but says there was a problem with installation and 'the data is not valid'.
I have tried support but without luck, oh and i have also changed the adaptor at pc world with the same results.
I hate wires running up the stairs and landing and my cats are mental. Hope you can help
Nic
  • Matt Major May 11, 2010
    'the data is not valid' - what is the exact message please.
Hi Bazildog,
the message reads 'there was a problem installing this hardware: 802.11.bg WLAN An error occurred during the installation of this device: the data is invalid'. I am then politely asked to click 'finish' and a litle box on the bottom left of the screen says that the install wizard had a problem installing this hardware and it may not work correctly.
Thanks for your time
Nic
Posted on Jul 21, 2008
Can't install DLINK USB on Windows 8?
You must use a wired connection to update the drivers
if possible for the usb adaptor
as you don't post the model number for the usb adaptor it may not have drivers written for Windows 8 available
Aug 01, 2017 | Computers & Internet
Driver for DWL-G122
This is the download link for the Dlink DWL-G122 wireless adapter, however you will first have to pick your revision version from the list, this revision number will be on a sticker on the usb adapter, simply chose the right revision version and you will see the download link. Once you have it downloaded, unplug the wireless adapter, install the driver then after it is done, or when prompted by the driver install, plug the device back in
http://www.dlink.ca/products/?pid=DWL-G122&tab=3
hope this was helpful
May 31, 2011 | Computers & Internet
D-Link DWA-130 running Vista
OK!! I figured it out!! Ok you need to go to the Dlink web site, cursor over to the tech support tab, on the drop down select DOWNLOADS, enter your Dlink wireless adaptor version(you'll need the box for these steps), ok now in the new window click downloads, choose and download the 130 one not the beta version, have a flash usb ready and save all downloaded files to ur usb flash, next insert your usb flash on ur laptop, open my computer select ur removable drive and double click the dlink software, after you do this it should bypass that prompt screen and you'll be able to continue your setup for your Dlink wireless adaptor.........hope it works for you cause it worked for me.....
Aug 30, 2008 | Computers & Internet
Computer needs ethernet card for highspeed internet
It depends on your computer and your operating system, but generally if you have USB ports with a Windows-based machine, then you can use a USB ethernet adapter. You plug the adaptor into your USB port, then the ethernet cable into the adapter.
Almost any electronics supply store ie Circuit City, Best Buy, plus Walmart and other big discount stores carry USB Ethernet Adapters. You can also try your local mom 'n' pop computer supply store.
http://www.dlink.com/products/?pid=133
I'm posting a link to a DLink adapter as an example *only.* There are other brand names out there that would probably do just as well.
Hope this helps!
Apr 03, 2008 | Dell Dimension 4600 PC Desktop
Buscando por drivers
Dont worry you can download from D-Link's website. However you need to choose correct Revision (Rev A or Rev B) before download. Its very clearly indicated on the website. You can proceed to links;
driver for Revision A
http://support.dlink.com/products/view.asp?productid=DWL%2DG510
driver for Revision B
http://support.dlink.com/products/view.asp?productid=DWL%2DG510%5FrevB
If you dont know what revision you have you can check these links
for Revision A
http://support.dlink.com/prod_img/revisions/DWL-G510v.jpg
for Revision B
http://support.dlink.com/prod_img/revisions/DWL-G510_revBv.jpg
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Feb 11, 2008 | Computers & Internet
Lost Cd
for Revision A
for Revision B
Jan 15, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Dfe-520tx/rtl8139
Hi Sabka, You didn?t mention which revision adaptor you had or what operating system you needed drivers for but Rev A supports Windows XP, ME, 2000 and 98; Rev B supports Win XP, 2000 and 98. Click on the link below and select the rev A or B link then download your driver(s). http://support.dlink.com/products/revision.asp Let us know how it goes and please don?t forget to rate the posting.
Jan 05, 2007 | D-Link Network Cards: DUB-E100 USB 2.0...
Computers & Internet Logo
128 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
