port forward the ports used by the ps3 avoid others being firewalled, port forwarding allows connections through the router firewall on specified ports
TCP: 80, 443, 5223 and UDP: 3478, 3479, 4658. UDP: 3658 should also be opened for voice chat.
see http://www.portforward.com/english/routers/port_forwarding/routerindex.htm for instuctions for your router.
Assuming you have turned on uPnP and NAT in the router and that did not work?
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
My husband is using an older operating system and laptop computer. Response to trying to connect to...
(More)
My husband is using an older operating system and laptop computer. Response to trying to connect to internet says: certificate authentication cannot be validated
I have a problem getting on the internet with my Itouch 3g and this is the the type of router i have...
(More)
I have a problem getting on the internet with my Itouch 3g and this is the the type of router i have ARRIS model TM702G/CT I can't seem to get internet on my Labtop either any help would be very appreciated.
