Fishfool67,
If it is like the one I just fixed, the sound had just disappeared gradually when playing. To fix this one first and foremost unplug the unit. Remove the two top side rear bumpers, the 2 screws on the upper back metal ledge, you can feel them if you run your hand along this lip and locate, then remove the 2 wires connected to the speaker, ( just connector clips). Remove the power plug clip(one screw) then the 4 top side screws, I like to hold tray up with one hand and unscrew with the other. once these screws are all the way out the tray should drop down a bit. Just slide to the rear and rest it on the lower part of the cabinet. The return 1/4" jack is the dirty one that needs addressed but why not do all of the jacks while we are here. You will need a contact cleaner solvent. I use one designed to be used on printed circuit boards. You should be able to find some at your local electronics store. The cleaner should leave no residue after it has evaporated, check the cleaner you have and make sure it is the correct stuff. Next we will spray all of the 1/4" jacks, just spray enough to coat them good, let dry and repeat. them reassemble the amp and plug and play. Don't forget to reattach the speakers. This should fix your problem.
TR
I had this problem with a bandit I just bought. I think the problem was the effects send/return jacks being a bit sticky. give them a clean, or for a quick fix plug a patch lead from the "send" jack straight back into the "return" jack!
First unplug amp to avoid electric shock. Then carefully unplug speaker and reverb wires. Then take the 4 screws out of the top of the case. This will allow the box, housing the electrical components to drop down.Slide the box out through the back of the case and look for 3 glass tube fuses.Check each of these to see if the filament inside isn't broken or burnt into. May not solve your problem but at least it's a place to start troubleshooting.
SOURCE: The channel select button on
please try to apply a lubricant contact cleaner on select button and press it many times(you can get contact cleaner from radio shack near you)
My peavey bandit 112 stopped working and there is still power running to it. It doesn't make any noise when turned on at all.
pulling my hair out..brand new bandit 112 transube...less than 6 months old..powers up..no sound!!!!
I have this amp and need to replace the fuses, but I don't know what kind I need to replace them. What do I need to purchase?
My Peavey Bandit 112 is less than a year old and it already stopped working. When I flip on the power switch, the light turns on and I can hear the speaker on and ready to make noise, but I get no sound when I use any of my three guitars. If I crank the volume all the way up, I can very faintly almost hear my guitar. I don't ever take my amp out of my room and never turn the volume up loud hardly ever. I do have a chain of pedals which are each power by a plug. Is this something I can fix myself? Thanks!
you are not going to believe this...I had this problem with my new Bandit in January, took it back to the dealer...he gave me a new one.
Now here it is april and the damn thing just quit!!!!
This is the second one and I'm getting tired of this ****.
