Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Check engine light comes on while letting off the gas?
Need way more info. type of bike and etc. if the check light comes on then there should be codes. could be simple like a vacumn hose or connection to what ever, just need more info on bike.
Posted on Aug 18, 2008
85 nissan p/u 4x4.....stalls out as soon as you let off the gas....pop the clutch and it fires off again......
sounds like possibly a TPS - throttle position sensor...is the check engine light on? if so you need to find out what codes are making the light come on
Dec 03, 2012 | 1985 Nissan Pickup
1998 4 runner limited looses power after driving for two hours
Check your gas cap to make sure you let it click a few times when tightening it. It can actually make the system go all freaky. The Check engine light will come on with a bad gas cap. I will do some checking and get back to you also. Good Luck
Apr 10, 2012 | Cars & Trucks
Engine light just started to come on and wont go off.
You do realize those type of check lights have been
on all vehicle for 30 years now ?
Check for any codes & diagnose them first
Same as any other dash light or vehicle problem
Aug 12, 2011 | 1998 Chevrolet Cavalier
ENVOY FUEL GUAGE PROBLEMS--- GAS GAUGE DOES NOT REGISTER ON FILL UP--- CHECK ENGINE LIGHT COMES ON WHEN YOU FILL UP -----THEN GOES OUT AFTER 1ST. 20 TO 40 MILES. BEN GOING ON FOR LONG TIME ONLY WORRY WHEN...
GMC sent me a letter saying that gas guage not working has been a problem and they will fix and pay half.
Also my mechanic says that it is common to get a check engine lite when you add gas to tank, especially when you fill it. Sometimes I will take off gas cap and let air out then replace cap and the check engine lite will go off. (usually). Nothing to worry about.
Aug 05, 2011 | 2006 GMC Envoy
Mitsubishi 2001 Eclipse Spyder (non turbo) 6 cylnder.... My check engine light came on today, I checked the oil, trans and coolant, everything is fine with those... Any other ideals, would be greatly...
if the check engine light came on it could be anything, that would not show up in your coolant, oil, etc. Have the code read. if you have recently got gas, and you didn't screw the gas cap on the right way, it will make the check engine light come on, that's how particular those lights can be. have it read and let me know what you find out.
Aug 08, 2010 | Mitsubishi Eclipse Spyder Cars & Trucks
Engine check light comes on and stays on for awhile then goes off. Dometimes when I fill the gas tank the check engine light comes on. is something to do with the gas cap or the instrument lights.
IF IT COME ON EVERY TIME YOU GET GAS.GAS CAP HAS BAD SEAL IT MORE LIKELY YOUR PROBLEM BUT LET AUTO ZONE SCAN IT FREE TO SEE WHAT TROUBLE CODE YOU ARE GETTING.
May 23, 2010 | 2003 Pontiac Bonneville
Car stalls out when I let off the gas a push the brake. Sometimes when I just let off the gas and let it slow down itself the check engine light comes on. But when it stalls out the check engine light and...
These had a couple of problems,,First the rubber intake tube to the throttle would crack on the bottom side, where you couldn't see it, causing stalling problems. Second,,the fuel shut off switch in the trunk. if it's in the lower left fender well under the cover/carpet flap, what happens the well area fills up with water. Push out the rubber at the bottom and clean out the debris,so the water can drain. The swtich would submerge,and getting corrodid. It's not water proof. Good Luck and hope that helps!
Oct 07, 2009 | 1993 Ford Probe
Just bought a 2006 chevy trailblazer. the engine light kees coming on. checked and replaced 2nd cylander coil. drove 150 miles engine light came ack on
I suppose the engine code said that cylinder was not firing or faulty? I would immediately get a compression check done on the engine. It is relatively painless. My burnt valves (compression 10psi vs 150psi) could not be diagnosed any other way. Does this help?
Jul 05, 2009 | 2004 Chevrolet TrailBlazer
2001 Jeep GrCh. starts, let go of gas, it stops. Battery not to
Besides the obvious: checking your alternator/charging system. If the check engine light is not on, or it comes on, and after awhile it comes off, then a couple of hours or days later it comes on again it might the crankshaft sensor. It happened to me, and it was a pain in the neck to diagnose as the check engine light had turned off and the computer wouldn't read any codes to diagnose the problem. My mechanic was trained by Mopar/Jeep, so he immediately knew what was happening.
If it is a dead or shorted battery, when the RPM's are up the vehicle will run, and you might notice a loss on power. Once the engine goes to idle and the RPM's come down the engine will die, as there is not sufficient electrical power generated by the alternator to supply the engine. A bad alternator will cause battery problems.
Mar 27, 2009 | 2001 Jeep Grand Cherokee
Lands Phones Logo
90 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
