Question about Pioneer Car Audio & Video
Pioneer GM5300T-760amp w/bridgeable
I'm having trouble connect this amp tp my 88 mustang. I have installed All pionner products in the car including the indash unit which has a usb, rear output cables, and sw ports. The light on the amp doesn't turn on. It only blinks and shuts off when I turn the radio on. What is going on???
  • 1,498 Answers
It sound like the Amp is trying to protect itself:
From the manual:
"To prevent malfunction of the amplifier and
speakers, the protective circuit will cut the power
supply to the amplifier (sound will stop) when an
abnormal condition occurs. In such a case, switch
the power to the system OFF and check the
connection of the power supply and speakers."
Although I'm leaning toward the speaker config, double check the obvious first.
  • power cables - both positive and ground heavy enough gauge?
  • speaker cables
  • solid connections, crimps
The next check is the speakers themselves. More info needed.
How many? 1, 2, 4?
Are they 8 Ohms? 4 Ohms?
How are they wired?
  • One to a channel?
  • Series?
  • Parallel?
  • Bridged?
In case you don't have one, here's a link to the
GM-5300t Owners Manual
If you still have problems, get back to me with speaker specs and configuration.
Hope this helps
Mike
Posted on Jul 20, 2008
How do i connect my Pionner AVHX2500BT on a 2007 GMC SIERRA SLE
You need this interface (or equivalent) if you do not have a Bose system nor wish to retain OnStar:
http://www.bestkits.com/product.php?part=C2R-GM29
If you have Bose, you need this one: http://www.bestkits.com/product.php?part=OS-4
Apr 17, 2014 | Pioneer Car Audio & Video
Amp going into protection
Is the amp bridged? If you only have one speaker connected to it, I sure hope so. How much power can that speaker safely handle and what is the impedance of the speaker? 2,4,8 ohm? A 1200 watt amp with only one speaker may be too much amp.
Jan 14, 2014 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
My 1998 land rover discovery i replaced the stock cd player with a pionner after market cd player everything is hooked up properly but cant get sound
Oh... Pioneer may be bad. I had a new tape player that was broken the day I bought it. Pioneer did replace it.
Apr 28, 2013 | Cars & Trucks
I have a pioneer cd head unit that i want to install but I dont know how to connect the wires. I could get it going but it doesnt power off when I turn the car off
check this web site for wire color info. it helped me on my 88 mustang. .http://www.stumbleupon.com/s/#1Pltxs/www.modifiedlife.com/car-stereo-wiring-diagrams-and-car-radio-wiring-diagrams// its free.
Nov 08, 2009 | 1992 Ford Festiva
4 chanel amp I dont know how to conected,to radioand one subwoofer
Hello canelo63,
Your question appears under the product listing for the Dual XPA4100 but the in the text you say the amp is actually a Jensen, so it's not possible to provide specific connection information.
But most bridgeable amps can be connected to a single subwoofer and the other two channels used to drive a set of regular speakers. I'd connect the front speakers to channels 1 and 2 and wire the subwoofer to the bridge connections of channels 3 and 4. On the XPA4100, the bridge terminals are the first (negative) terminal on channel 4 and the last (positive) terminal on channel 3.
Hope this helps.
Jun 01, 2009 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Wiring
Usually an 800 watt peak sub would be a 400 watt rms. Hmmmm. Anyway, just bridge the amp (1x 380) nd keep the gain up enough to stay clean. Watch the sub and turn up gain until it starts to distort, then back it down a hair. Do this with the CD players volume up 2/3 to 3/4 volume with the BASS and treble at zero (bass better at minus 4 or so if you are a bass head! Hope thishelps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Pioneer GM-5300T Car Audio Amplifier
No power to my pioneer gm5300t
arcanum,
good day bro, from your Pioneer amp supply line do you also see a terminal marked as " System controller" ? did you also supply 12V DC to this terminal?
the standard power configuration for Pioneer Car amps would be:
12V Dc (+) supply / ( - ) supply ground / System Controller ( supplied by +12V DC)
12V ( + ) supply and The ( - ) supply ground is for stand by power, once you connect the supply through this terminal you will now have the stand by power but will not power on the unit even the LED power indicator.
System controller terminal, this should be supplied by ( + ) 12V line to power up the amp. this serves as the ON/OFF switch for the amp.
cheers,
mark
Jan 25, 2009 | Pioneer GM-5300T Car Audio Amplifier
It sounded like you checked, but I had to ask.
Lets see if the Bazooka is the problem:
If you have two other speakers around somewhere, you could try hooking them up (one to a channel, un-bridged). Start with the gain at it's lowest and slowly increase it.
If they work, good news. If not, we've isolated the problem to the Amp.
Your Bazooka: Is it a double or single speaker?
Some tubular models don't allow easy access to the back of the speaker to find out the impedance rating.
Speakers rated at 4 Ohms or less wired parallel on bridged connection will trigger the Amps self protection mode.
This test should tell you if it's too low.
Try your bazooka on a single channel (instead of the bridge).
Try these and get back to me.
Good luck
Mike
Jul 20, 2008 | Car Audio & Video
Car Audio & Video Logo
401 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
