Hi. I need to make my new Philips DVP3146K multi region. Is there a code I can enter on the remote_
  • 376 Answers
Keep Tray in eject position
Press Setup from remot
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
OR
open tray
press 98790
Posted on Aug 14, 2008
How To set a Philips DVD player dvp5996k to "multi Region" ?
There's a lot of useful information on the videohelp.com website.
Philips DVP5996K region code
posted by satish_z2002.
  • Please turn off all power using remote
  • Turn On Power
  • Eject Tray - Player will display NO DISC
  • Enter Setup and navigate to preferences page
  • Type 138931 on your remote
  • Player will display Default Region Code
  • Use up down arrow keys and select 0(Zero) for All Regions
  • Hit Enter
It's now region free.
DVD Player and Blu ray Player region codes
Jan 19, 2014 | Philips GOGEAR Audio Players & Recorders
Crack code
here u go rate me Fix ya
1/press setup
2/go to the prefernces page.
3/type 9 6 5 3
4/select region
solved 100% by Fix_You
Aug 18, 2008 | Philips DCP855/37 Portable DVD Player
I need a Philips DVP3100/79 region unlock code
-Open disc tray
-Press "Setup" (on the remote)
-Highlight "Preferences" (bottom of setup screen)
-Enter "138931" on the remote
-The current region code will now be shown
- Use up arrow button on remote to select 0 to make it multi-region
-Press "OK" on remote to confirm change
-Press "Setup" once more to return
Oct 21, 2010 | Philips Televison & Video
L need a multi region code for a panasonic dmr-ez47v.
Panasonic DMRs cannot be unlocked for muliti region simply by entering a code form the normal remote or front panle controls.
Panasonic machines require a special remote control in order to make them multi region. Panasonic dealers will unlock your machine for you but will charge you - this is expensive.
Alternatively, if you search eBay you will find devices that will unlock your machine that can be purchased or "rented", for considerably less than a dealer will charge.
Nov 07, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Change area code of device please
1. Hack for PAL p-scan using the supplied remote is "play", "159 222 023 00" , then press "play" for region 2 player
2. Enter RC6 command via Pronto
[For multi-region using a OneForAll (URC7560), to generate the RC6 code:
2.1. The remote should be set up to control the DVD (setup code 0539).
2.2. Press the DVD button.
2.3. Press the Magic button.
2.4. Press 085.]
2.5. The display should read '----'.
2.6. Enter the following with the normal Philips remote:
[On newer models, there appears to be 11 spaces in which to enter a code].
222 222 005 255
The player should now be able to output pal progressive scan + be region-free.
May 23, 2009 | Philips DVD963SA DVD Player
Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
moz-screenshot.jpgmoz-screenshot-1.jpgRegion
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
Feb 28, 2009 | Philips Televison & Video
Convert to o multi-region
  • Switch on and open the tray.
  • Press [SETUP] on the remote control. Setup menu will appear.
  • Highlight "PREFERENCES" and press [ENTER]
  • Press [2][5][2][3][1][5][LEFT][DOWN]
  • "Region Code: 2" will be displayed on the screen
  • Press [0] to set the player to region free (or [1-6] to set region manually)
  • Press [SETUP] to exit
Sep 22, 2008 | Philips PET710 Portable DVD Player
Regional code
open tray
Press PAUSE
enter 0000
The region code set page should appear.
Set code. 0 for multi region
Press PAUSE.
OR
Make sure your TV is on and the DVD player is active on it
Unplug the DVD player
plug it back in
wait for text "nodisc" to appear on the DVD display
Use remote control to open tray (tray must stay open)
Use remote control to Press "Pause" (you won't see anything)
On the Remote control number pad enter the number "0000" (4 zeros)
The region code setup window will appear on your TV
on the remote control number pad enter number "0" (zero)to set multi region
Use remote control to Press "Pause" again
close tray
Jun 06, 2008 | LGDVB418 DVD Player
About region code
You need to use a One4All Universal remote for regions 1 & 3
1. Switch on the player
2. Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
Mar 28, 2008 | Sony DVP-FX810 Portable DVD Player
Philips DVP3144 Region Change
The fix on the DVP3120 was as follows. I don't know if this works on 3144 - would like to know.
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Nov 30, 2007 | Televison & Video
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
