Question about Karcher 2500 PSI Pressure Washer
Karcher 2400 pressure washer with honda engine. my problem is that i've installed a new rebuild kit in the pressure pump assembly, and now, when i reinstall the assembly back on the engine, i cant even pull start the engine over. its too tight! when i loosen back on the pump assembly, i'm able to pull the engine over. what have i installed wrong from the rebuild kit??
  • 2 more comments
  • jborges189 Jul 20, 2008
    can anyone give me assitance with the rebuilding process of the karcher 2400 pressure pump? like maybe a detailed step-by-step procedure? the only thing that i have to go on is the blown-up assembly reference paper that came with the kit, but that damn thing is hard to follow. thanks
    yes, it's lined up properly. i dont think that i would even be able to bolt it back up otherwise. thanks
  • kgcsinte Mar 12, 2009
    I have the same washer, opened mine up and all the oil came out. Ok, how did you get the oil back in and what type of oil did you use?
  • Anonymous Mar 18, 2014
    Power washer pump back pressure making it hard to start
  • 3,037 Answers
The pump is correctly oiled and lined up on the camshaft, correct?
Posted on Jul 20, 2008
  • 19,396 Answers
Difficult to know from here, check all the screws see if there was a required strenght on some of the screws. You should take it apart and assemble again.
How to rebuild High pressure pump
You can get a repair or rebuild kit for this pump at any store that sells Karcher. You need to have a torque wrench and a set of picks to remove the packing. Take the head off the pump and pull the packing and the valves. Replace them as the instructions show and then put the head back on.
Sep 07, 2015 | Karcher G 3050 OH
Low press output not like when new
The pressure drop on this unit is normally caused by failing water seals in the pump. In order to repair it you will need to purchase a repair kit for the pump and rebuild it. The part number for the kit is 9.011-852.0. If you would like to purchase it we have it available and are a Karcher certified repair facility. Order by visiting www.landanw.com or calling 800.247.8103.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 05, 2011 | Karcher PSI Electric Pressure Washer
Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Oct 02, 2009 | Honda Karcher G4000RH Pressure Washer
Pump want start no pressure on spray
you need a bladder and seal rebuild kit , buy from your local small engine guy and you can do yourself or have him do it
Aug 26, 2009 | Karcher 2500 PSI Pressure Washer
I have a karcher 2400 psi pressure washer and it doesnt get water pressurized when pulling wand trigger.
the most comon problem with thease is a stuck bypass valve, this is the valve that alowes the water to bypass round the pump when the triger is closed, when they stick all of your pressure runs around the pump and not out of your nozzle,,
its located in the centre of the pump on the top, undo the 2 cap screws pull out valve greese and re fit
Jun 08, 2009 | Honda Karcher G2400HH-R Pressure Washer
Need throttle sping help
Take spring to local harware or home improvement store (Ace, Lowes, Home Depot, etc.) and get a similar spring.
Jun 07, 2009 | Karcher 2500 PSI Pressure Washer
Pressure surge on and off for 2 seconds w/ new Karcher
It can be one of three conditions,
  1. The water supply in is not sufficient
  2. The pump oil is low
  3. The seals are bad in the pump.
I would check the first one first as this is the most common problem.
The water supply hose should be a high volume hose of at least 1/2 inch but 5/8 inch or greater is best.
May 08, 2009 | Honda Karcher G2400HH-R Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
624 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
