Question about Philips 50PP9202 50" Rear Projection Television
Hey there :)
I just found a good deal on Philips-50PP9202-Epic-50-HDTV-Ready/dp/B000066R5M
but it has the convergence color problems.
do you have step by step instructions on how to replace the ICs and ...?
hopefully the parts wont cost much :)
Ali
Posted on Oct 20, 2008
Color won't converge
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 27, 2009 | Philips 51PW9303 51" Rear Projection...
Power seems to be on, but it does not turn on
There is a loose connection inside the TV or component damage, it need to be repair by resoldering the component first.
May 31, 2009 | Sony KV-32S26 32" TV
Phillips HDTV looks like it is in 3D
Your convergence ic's went bad and possibly took out the fuses in that circuit. I believe they are stk392-120's on that set. Also, check all the resistors around them. Should be located on two heatsinks near front of chassis. Good luck.
May 19, 2009 | Philips 50PP9202 50" Rear Projection...
TV Color
You need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt metal film resistors. You can get the ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jul 04, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 50PP920217F remote/color
Requires convergence amp IC replacement ( two) and check
resistors in vicinity of IC's....fairly technical repair....Please read
some of my convergence solutions and let me know if you want
step by step instructions............................T.
Jan 23, 2008 | Philips 50PP9202 50" Rear Projection...
Philips 66P920217F Chassis DPTV305F
I fixed that issue on my in-laws set - twice. Both times there was a different reason. First time, I went to the menu ON THE SET ITSELF, not the remote, and had to select an option. Don't remember what, but should make sense when you poke around. The second time was quick and easy, the cable company had swapped the blue and green component cable. Good luck!
Nov 02, 2007 | Philips 50PP9202 50" Rear Projection...
Blue color warps screen
Blue convergence IC bad....change both IC's and check
current limiting resistors for over-heating.....let me know if
you need more info..........................T.
Oct 21, 2007 | Philips 50PP9202 50" Rear Projection...
Philips 50PP9202 50 in. Rear Projection HDTV-Ready Television?
Hello Anthony14,
This is an indication the the red convergence amplifier has goone bad you will need to replace the convergence correction modules. Now before replacing these you may want to make sure that the bias resistors and the zener diodes are ok. The convergence ICs are part number STK329-110 or STK329-150.
I would suggest that you get a schematic and equipment to make the needed tests, or take the set to a shop to replace the bad components.
I hope this helps,
Thank you,
Shuttle83
Oct 14, 2007 | Philips 60PP9202 60" Rear Projection...
Color Set-up Problem
This set has had many problems with convergence amps going bad. More than likely this is what is going on. You can take board up and look for a loose connection first and if not then resolder anyway, but you probably need to order the STK's 392-*** Not sure what they are in this set maybe 110's. Replace both and the 4 resistors that stands up next to them.
Sep 06, 2007 | Philips 50PP9202 50" Rear Projection...
Philips 50pp9202, no picture but sound is fine.
I have the 51 inch of this model and I have found that usually it give you some indication before going completely out. Like color problems, sound, or just video disappearing. Most of the time it will be the convergence amps going bad, but you should have seen some color distortion. If not then it could be the vertical output. TDA8177 needs replacing and check caps around and diode, If not this then look for open fuse in HV line to crt's. Also power supply fuse like 1900, 2004, 1300, etc.
Mar 26, 2007 | Philips 50PP9202 50" Rear Projection...
Philips 50PP9202 50" Rear Projection Television Logo
153 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
