posted by annu22 on Jul 20, 2008
am making project on school bus managment system but am not able to access data frm the table or insert in to table
am using following code kindly guide me if thr is any error in code
If cnn.State = adStateOpen Then cnn.Close
cnn.Open
Set rst = New ADODB.Recordset
rst.Open "studrec", cnn, adOpenDynamic, adLockOptimistic, adCmdTable
With rst
.AddNew("Name") = TXTNAME.Text
.AddNew("fname") = TXTFNAME.Text
.AddNew("area") = TXTAREA.Text
.AddNew("class") = txtclass.Text
.AddNew("root") = txtrootno.Text
.AddNew("bus") = txtbusno.Text
End With
rst.Close
cnn.Close
Best Solution
posted on Jul 21, 2008
Proper syntax is:
With rstTemp
.AddNew
!FirstName = strFirst
!LastName = strLast
.Update
End With
Do you have the ADODB library loaded?
While in "Code" view...menu/tools/references ... look for a check by "Microsoft ActiveX Data Objects x.xx..."
If you don't have ADO reference library then setting ADODB recordset won't work no matter what syntax you use.
Hint: try using Ctrl+J while you code. The library will show you available syntax as you type.
With rstTemp
.AddNew
!LastName = strLast
.Update
End With
Rating Locked! (?) annu22 has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Microsoft Windows XP Professional
Email this problem
Email this problem
Can you Help with these Operating Systems problems?
Set up a DNS (domain name...
Can anyone reccomend a free DNS... Answer This...
Microsofts Window Media Player
How do change Media player to... Answer This...
desktop software
desktop software
want 2 download desktp software... Answer This...
windows media Player for CE...
there are Some Media Player... Answer This...
Repair Service
Find Operating System Repairman Near You:
