Question about HP Photosmart 435 & HP Photosmart 145 Compact Photo Printer (Pack) Digital Camera
No display power lite comes on no display have tried unplugging no dice
  • Anonymous Mar 27, 2009
    No information on screen
  • havefun Mar 28, 2009
    where do I find solution to no lcd
  • 3 Answers
Hi just posted a fix for this if you look at the website Good luck!
Posted on Jan 10, 2009
Power lite on rca flat screen flashes 4 times
I would suspect either the Power supply or the main board. I can assist you with basic trouble shooting to determine which board it is if you would like. Just respond to this same post for assistance.
Jan 01, 2013 | RCA L42WD22 42 in. LCD Television
2001 PT Cruiser,Trac off lite & Brake come on and off. everything checks OK and replaced Computer Module.
'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar.
Traded in '02 Silver Touring Edition w/87,000 miles
Jul 26, 2012 | Chrysler PT Cruiser Cars & Trucks
I have an AVR 235 Receiver. The front display does not light up nor is there sound. The power indicator and standby light comes on/off. I have followed manual instruction with the OSD button, etc., tried 3...
The failure of the front display indicates that there is a electronic fault.
So you need to check the power supply to the display panel, check the +5 to the processor and siplay drivers including the filament voltage to the display and the negative grid to the display. If not trace back to the power supply unit.
If these are present with no display check the linking cord to the display. Check the parameters of the processor which can confirm if the controller is working. if not you will need help for replacement of the processor and also since this is high densitty boad where service requires jigs and equipments.
Sep 15, 2011 | Harman Kardon AVR 235 Receiver
The desktop will not boot. When powered on, the fans start, and the optical drive cycles repeatedly. Nothing on display - light on display stays yellow. I have tried unplugging rhe CD drive. No dice. I...
Bios is checking to see if the components are recognised.. usually keyboard is "seen" first. I have to concurr with you that given the things you mention, the mobo is indeed toast, especially as there are no beeps on boot up that would indicate a specific error
Jan 03, 2011 | AOpen (S661GXM-U) Motherboard
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
Acer aspire 4330 will not boot up
Can you plug a external monitor into the machine, most laptops have that serial port. If montor comes on, you have bad display or connections, If not you have problems with laptop....Good luck
Apr 23, 2009 | Acer Computers & Internet
I bought a TrippLite Internet Office UPS surge protector in January 2009. I have misplaced the manual. Recently it began to beep for no reason. There is no power failure. It was so annoying I had to unplug...
this unit come with 4 with battery backup of 12v 7ah. check what are the indicator display shown?
it very diffcult know what the problem if u can give more info. u can try to replace the battery with new batts.. and test the ups if it not beeping again it show the battery problem. or maybe you had plug in more the the power consumtion that why it keep sound the alarm indication overload try to serperate the load. if u wan a user manual go to this website to download the manual:
u will get will u wan...
Apr 12, 2009 | Tripp Lite Tripp-Lite Internet550U 550VA...
RCA TruFlat HD27F534T - No Power
Does the red light come on on the front of the TV to let you know it is getting power? Does the menu come on? If the menu desn't come or the red light you might need to take it to RCA or a good repair place. If you checked different outlets it sseems to be a TV problem.
Sep 05, 2008 | RCA TruFlat 27F520T 27" TV
No power
why didnt you hook it up to your wiring harness and were is the red wire hooked up the yellow is the memory wire make sure you have a good ground
Feb 09, 2008 | JVC Sirius KD-G300 CD Player
Cameras Logo
368 people viewed this question
Top HP Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
