Need to add speakers to our 19
We had an Emerson 19" LCD TV w/built-in DVD player in our RV (a hybrid trailer). We have trouble hearing the sound when the A/C is on or if it is raining. We can turn the volume up to its max, but still need to have the subtitles on (a pain!), plus then you can hear the sound OUTSIDE the trailer because it's up so loud. We don't want to be annoying other campers at night, and don't want to have to be reading subtitles all the time.
We'd like to hook up an inexpensive set of speakers to place next to the sofa and next to the dinette. Any suggestions?
  • hozz2 Jul 20, 2008
    Well, we had thought about that, but it's a small trailer (19') and we'd like to avoid having the receiver and 5 speakers. We were hoping to just be able to find two small bookshelf-type speakers that would just plug right into the TV's AUDIO OUT . Is that a possiblity?
    Master:
  • 726 Answers
Yes just by a 5.1 surround system cheap set 50 dollars does the trick
Posted on Jul 20, 2008
Im trying to connect my coby dvd player to my samsui tv
Hi Maria,
You can hear the sound means your TV and the DVD player are working well. May be the video connecting cord ( yellow connector) between the TV and DVD player has gone bad. Please try replacing it. For testing, you can interchange it with any of the two sound connecting cords which have white and red connectors. I hope it helps.
Jan 23, 2016 | Sansui 19 in. LCD TV
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
Emerson lcd tv w/ dvd 19"
Contact the authorized service center for Emerson. The main board to your TV is faulty. A replacement should be done. Gopakumar Gopalan Google
Feb 27, 2014 | Televison & Video
My tv volume is on 100, however, you still can't hear it
first is turn it down to a lower level:
look to see if sound with a DVD connected to a rear input.
look in menu to see if speakers are switched to OFF.
look also if set has external speaker hookup set not set to external.
failing you have a audio circuit problem in the TV.
Nov 06, 2012 | Magnavox 26" LCD TV with Built-in DVD...
I put in a dvd, it starts to read it, and in a couple of seconds it ejects
Hello; There are many laws and rules controlling what you can watch on all DVD players, built into a TV or separate player. If you go buy an MGM or other dvd of some movie at Walmart , Best Buy ETC it should play in your DVD player, But if You or somebody " Burned a DVD" , It Likely won't play. If The DVD is an original store copy and still won't play, the DVD chassis must be replaced. BIG BUCKS. Just buy a Cheap DVD player and plug into the jacks on the back of the TV and save a TON of money. John
Jun 27, 2011 | Emerson LD195EM8 19 in. LCD TV
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
May 22, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Hooking up the dvd player surround sound to be able to hear the television thru it
jimmy4151:
Name & model # of television & DVD player, Please.
Usually if the DVD player is not an Amp, then the surround sound comes from the DVD player through the TV out through the speakers??
Jun 15, 2008 | LG 42LC2D 42 in. LCD HDTV
Emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
If you will allow me to make an assumption, you do not have a 5.1 surround system connected to your DVD player. This is a common experience with users of a standard TV or stereo receiver if a movie is being presented in 5.1.
In a surround sound system the center channel speaker provides almost all the vocal tracks while the side channels will provide music and some background noises. You'll still be able to hear the voices in your side speakers, but it will be muted and over powered by music or sound effects.
Some DVD players allow you to "Downmix" the surround signal to stereo. You might want to look around your sound setup on the DVD player or check your owners manual.
Hope this helps.
Jon
Go Ahead. Use Us.
May 22, 2008 | Emerson EWD7003 DVD Player
Sound
You may have your audio presets on your DVD too low. check your menu to make sure those presets are correct. As for Surround Sound it is a sound technique that involves having multiple speakers to give the impression of moving sound, not just hearing from the left or the right as in stereo, but hearing the way you are exposed to in real life sound moves around you this combines the doppler effect from many directions at once, example: as a car move towards you with its horn blowing the sound gets louder as it passes you the sound gets lower however, each of your ears hears the sound diferently, thats how come you can tell if the car is to your left or to your right vs coming straight at you and as it passes you, you can tell if the car is on your left or right from your rear. Surround sound is an attempt to do this without actual movement. I hope this helps.
Sep 07, 2007 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
258 people viewed this question
Top Televison & Video Experts
