Question about Car Audio & Video
Remote will not arm or disarm - Car Audio & Video
    Master:
  • 726 Answers
Check to see if the batteries are fine
other wise it will have to be reprogramed
Posted on Jul 20, 2008
Car security light won't stop flashing while driving?
Are you disarming the system with a remote or disabling by inserting the key. On some vehicles you may have a remote control key fob and a master key that works with no buttons, it is a straightforward key with no buttons that temporarily disarms the vehicles alarm for use, it does not fully disarm. When the alarm system is armed through the remote it can only be disarmed through the remote via the transmisson of a coded signal. Have you got these 2 different kinds of keys?
Please add detail and resubmit the query
Jun 08, 2015 | Toyota Vehicle Parts & Accessories
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
Car won't start.Theft light blinks,clicking sound under hood and thumping like horn wants to go off.Seems like it's stuck in anti theft mode
anti theft light should blink every few seconds.
try disconnecting the battery for 15 minutes.
Anti-Theft-Perimeter The perimeter anti-theft system consists of the following components:
  • anti-theft indicator (THEFT)
  • remote anti-theft personality (RAP) module
  • hood switch
  • keyless entry remote transmitter
  • deck lid ajar switch
NOTE: The remote entry features will not function when the ignition switch is in the RUN or ACC position.
Up to four keyless entry remote transmitters (15K601) can be programmed at one time.
The keyless entry remote transmitters :
  • Are programmable.
  • Must be set at the same time.
  • House four buttons.
  • House three buttons (Mexico Anti-Theft System only).
Programming
Refer to Section 501-14B.
Inputs and Outputs
The remote anti-theft personality (RAP) module receives input from the following components for anti-theft operation:
  • Hood switch.
  • Deck lid ajar switch.
  • Keyless entry remote transmitter.
  • Power door lock switches (LH and RH).
  • Door courtesy input.
The RAP module distributes output to the following for the anti-theft system:
  • Power door unlock relay.
  • Power door lock relay.
  • Liftgate unlock relay (Wagon)
  • Park lamps relay.
  • HORN relay.
  • Dome lamp.
  • THEFT indicator.
  • Deck lid release.
Arming
The anti-theft system can be armed if:
  • The ignition switch is in the OFF position.
  • The panic alarm is off.
  • All doors are closed.
NOTE: If a door is open, the anti-theft system is prearmed and waiting for all the doors to be closed. The THEFT indicator will remain illuminated for up to 30 minutes waiting for all the doors to be closed. If a door remains open after 30 minutes, the THEFT indicator will turn off and the system will return to a disarmed state. After all doors are closed and the 30 second prearm (continuous THEFT indicator illumination) is complete, the system is armed.
NOTE: If the theft LED does not flash after 30 seconds, check the LED FLASH PID to see if the feature is enabled.
The anti-theft system will be armed when the lock button on the keyless entry remote transmitter is pressed, all doors are closed and 30 seconds have elapsed.
When the system is armed, the THEFT indicator will flash quickly until the system is triggered or disarmed.
Disarming
NOTE: Using a key in a door lock cylinder to unlock is not a valid method of disarming the anti-theft system.
Untriggered System
NOTE: If the driver arms the system and remains in the vehicle, an untriggered system can be disarmed by turning the ignition switch to the ON position.
An untriggered alarm system can be disarmed by pressing the unlock button on the keyless entry remote transmitter.
Triggered System
NOTE: If the hood or trunk are open when the system is armed, it must be closed and opened again before it can trigger an alarm.
An armed anti-theft system can be triggered by the following conditions:
The deck lid door, liftgate, hood or any door is opened using a key, inside door handle, hood release, etc.
  • The keyless entry remote transmitter can activate a panic alarm which is similar to the anti-theft alarm, but does not cause the THEFT indicator to flash.
A triggered alarm system can be disarmed by:
  • Pressing the unlock or panic button on the keyless entry remote transmitter.
  • Turning the ignition switch to the ON position.
Alarm State When Battery Power Is Cycled
When the RAP module is supplied power the first time at the vehicle assembly plant, the system will be in the disarmed state. The RAP module will remember whether it is armed, disarmed or triggered in its non-volatile memory. When the battery positive cable is removed and then reconnected, the system will return to the state it was in just before the battery was disconnected. If the system is in any prearm state, then the system will return to a disarmed state when the battery is disconnected and then reconnected.
Nov 06, 2010 | 1999 Mercury Tracer
I have a viper alarm on my car that wont shut off nor i cant start the car..and i have tried the button under my dash, how Can i shut it off??
was it a professional or shade tree install? the following is off vipers website:
disarming without a remote control
This feature allows you to disarm the security system without the
Remote Control should it be lost, damaged, or disabled. In order to
disarm the system without a remote remote control, you must have
the vehicle’s ignition key and know where the Valet button is
located. Be sure to check with the installer for the location and the
number of presses of the Valet button required to disarm the system.
To disarm the security system,
turn the ignition to the ON position.
Press the Valet button the
preset number of times (one to
five times) within 15 seconds. After five seconds the system will
disarm. If the system does not disarm, you may have waited too long;
turn the ignition off and on and try again.
if that doesn't work try this other
valet mode
You can prevent your security system from automatically arming
and triggering by using Valet Mode. This is very useful when
washing the vehicle or having it serviced. In Valet Mode, the
security system will not arm, even with the Remote Control, but
all convenience functions (door locks, trunk release, etc.) will
continue to work normally.
To enter or exit Valet Mode:
1. Turn the ignition on.
2. Turn the ignition off.
3. Press and release the Valet
button within 10 seconds.
The status LED will light solidly if you are entering Valet Mode,
and it will go out if you are exiting Valet Mode.
May 08, 2010 | 1994 Honda Civic
When i arm and dis arm system i get error beep?
Hit f and then unlock
You may have lock out the remotes. If that doesn't work DEI has a one yr gurantee on remotes. In your box there should be a registration card. Call them.
Jan 26, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
1995 Nissan Maxima alarm system
Hey, I bought my 1995 Nissan Maxima GLE brand new back in July 1994 with factory installed alarm, it just doen't make any sound when you arm or disarm it with remote. The only way you can tell whether it is armed or disarmed is from the lever position of your doors and the blinking red light under the dash. Only the newer versions of Nissan/Infiniti's has the "Audio/Silent" mode button on the remote which allows you to activate/deactivate you car alarm with an audiable sound or no sound at all. No worry, there is nothing wrong with your remote or car alarm.
Jun 17, 2009 | 1995 Nissan Maxima
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Replaced the alternator, now anti theft won't disable
The ignition lock anti-theft switch (19A438) detects if the ignition key cylinder is broken or "slam pulled" during a theft. The ignition lock anti-theft switch is always monitored by the remote anti-theft personality (RAP) module. This allows the alarm system to be triggered in the case that the ignition lock anti-theft switch detects tampering of the ignition key cylinder (even in the event that the alarm is not active at the time).
Refer to the Section 501-14B for more details on the keyless entry remote transmitter (15K601).
The door open warning lamp switch (14018) communicates to the RAP module through the generic electronic module (GEM). This input to the RAP will cause the anti-theft alarm to be sounded if the anti-theft alarm was armed.
The door disarm switches are assembled into both LH and RH lock sets. The door disarm switch must be triggered before the mechanical lock unlocks. This is to prevent the anti-theft alarm from activating when it should have been disarmed.
The RAP module controls the anti-theft system and is the brains of the keyless entry system. The RAP module communicates with the GEM to request that the interior lights be turned ON/OFF with use of the keyless entry remote transmitter, and the GEM communicates to the RAP to inform when the door is opened. Refer to Section 418-00 for inter-module communication.
The RAP module has three wire connectors attached to it:
  • The antenna for the keyless entry remote transmitter.
  • 26 circuit connector (C256).
  • 22 circuit connector (C257).
In addition to the perimeter alarm that uses the door open warning lamp switch, the RAP module also uses the ignition lock anti-theft switch and the autolock/relock feature to prevent theft of the vehicle. For a full description of the autolock/relock system, refer to Section 501-14B .
The THEFT LED is found on the instrument panel between the tachometer scale and the needle pivot point. The LED is illuminated during prearming and flashes when armed or triggered.
Prearming and Arming the System
The system can be armed if:
  • The ignition is OFF.
  • The PANIC alarm is OFF.
There are two ways to prearm the system:
  • Press the LOCK button on the transmitter.
  • Open a door, press the power door lock button and close the door.
After 30 seconds the system will be armed and the theft indicator in the cluster will flash every two seconds.
Disarming an Untriggered System
An armed system will be disarmed with one of these valid actions:
  1. Pressing the UNLOCK button on the transmitter.
  1. Placing a key in the door and turning to UNLOCK.
  1. Turning the key to RUN or ACC.
The anti-theft alarm can be triggered by the following conditions:
  • The ignition cylinder is damaged with or without the RAP being armed.
  • A door is opened without disarming the armed RAP module.
The remote transmitter can activate a panic alarm which is similar to an anti-theft alarm, but does not deactivate the starter or cause the theft indicator to flash.
Disarming a Triggered System
If the system has been triggered, (the horn honks, the lights flash, and an external starter interrupt relay is engaged), the system can be disarmed by:
  1. Pressing the UNLOCK or PANIC button on the transmitter.
  1. Putting a key in the door and unlocking the door.
  1. Turning the ignition to RUN/ACC (Turning the key to RUN/ACC will not disarm an alarm that has been triggered by the ignition lock anti-theft switch.).
Apr 10, 2009 | 1997 Ford F150 Regular Cab
1997 accord the door lock remote won't work and it only will beep a couple of times when you press the top button on the remote. checked the fuses and changed the batery.
The buttons on the remote do different things.Number I turns the beeping and alarm either on or off. (2 different settings). The number II button Arms and disarms the car. One beep is armed and two is disarmed. Try it out now, You'll understand.
Dec 03, 2008 | 1997 Honda Accord
Viper won't remote start and arm/disarm only works sometimes
Greetings Microluv,
Simple question, have you changed the battery in your remote lately? I was having similiar issues with my remote start and it was a simple matter of changing the batteries in the remote.
I figured lets eliminate the easy stuff first. :)
Dorothy
Go Ahead. Use Us.
Jul 07, 2008 | Viper RCVGC022 Remote Control
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
