Question about Creative Labs Zen Neeon MP3 Player
Zen neeon 5GB
When I turn it on it shows the little icon for "lockek". It doesnt react to the "lock", "unlock" switch.
  • 3 more comments
  • gitvet Jul 24, 2008
    hi,i tried reseting the whole thing with a needle in the opening near the lock switch,nothing happened,it still shows locked,then it turns off.
    ok,so how do I fix that?
    I unscrewed the 2 screws,how do I get the battery out?
  • 2,071 Answers
Just hold on the power "on" for 1 minute,then it will unlock..
hope this may help;
Posted on Jul 24, 2008
  • LORETO LACARON
    LORETO LACARON Jul 24, 2008
    Try this option also here's a reset hole by the side of the player. Try reseting it.
    It can locked sometimes, and fix itself after a while. no apparent reason. reset, run the battery down and recharge.
    Hope it helps.
    this is from the creative site:
    The recovery mode consists of these four operations.
    * Clean Up: It is the least destructive operation. It scans a player's
    hard disk and removes any invalid links from the music library. It does
    not affect music files themselves. It is recommended that you perform
    "Clean Up" first before formatting or reloading the player's firmware.
    It is recommended that you clean up regularly if you frequently transfer files between a PC and your player.
    * Format All: It is the same as a Windows format performed in a PC, and
    consequently all contents will be lost after a format.
    * Reload Firmware: Reloads the player's firmware (Operating System). It will also format the player.
    Note : It requires the player be connected to a PC that meets the
    player's minimum system requirement. Select this option ONLY if you
    have access to a PC and you have downloaded the necessary firmware to
    install.
    * Reboot: Reboots the player. You can reboot the player
    after performing a clean-up or format, or reboot it without performing
    neither of them.
    It is recommended that you try these operations
    in the following sequence: reboot the player; clean up and reboot;
    format and reboot; and finally, reload the player's firmware.
    If
    your player seems to stuck in the recovery (rescue) mode, you can try
    the "reboot" operation first, and format the player if necessary. If it
    fails to reboot, you will need to connect the player to a PC, and
    reinstall its firmware. For a detailed instructions on how to install a
    player's firmware, please refer to Updating the firmware on a Creative
    MP3 player, or refer to the Web Release note of the firmware download.
    Unlike other hard disk based players, Zen Neeon does not have a rescue
    mode. Though there is a Player Recovery Mode , it is for use when
    updating its firmware only.
    1. Detach your player from your PC , and ensure that it is turned off.
    2. Close all active applications (for example, Internet Explorer,
    Windows Explorer, or Windows Media Player etc), as well as background
    applications such as Norton anti-virus applications.
    3. Download
    the latest device driver if you have not installed any drivers for your
    player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe.
    4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen.
    5. Hold down the Play/Pause button while connecting the player to a PC's USB port.
    6. When the Creative logo appears on its screen, release the Play/Pause button.
    The player is now in Player Recovery Mode
  • LORETO LACARON
    LORETO LACARON Jul 26, 2008
    1) You do not have to remove any of the top nor the screen cover. The
    screws under the top cover only hold on the plate. Simply remove the
    other parts as shown and slide the whole "guts" out the bottom. The
    screen cover breaks very easily at the top corners due to the adhesive
    and "pins" in the corners.
    2) When removing the bottom cover it is easier to start at the back
    corners. The plastic has notches cut out at these corners so you can
    get your screwdriver under it easier.
    3) Unreal-Parts is correct. Remove the keypad by depressing the 2 tabs
    inside which clip the keyboard in place. Trying to slide the keyboard
    may damage the keyboard connector.
    4) When sliding the "guts" out be very careful not to scratch the
    screen. The small metal support pieces above and below the keyboard are
    easily bent and can scratch the screen very easily due to sharp edged
    and burrs.
    5) If replace the hard drive without disconnecting the battery (not reccomended) you MUST press the reset switch before you power the player back on. Evidently the player keeps the library in memory.
    6)The battery is together with HDD,a button kind cell battery.
    Master:
  • 382 Answers
Mp3 players are too fragile in their inner circuit and to handle..So i would rather advice you to take your Mp3 player for Service at any Service Store rather than trying anything by yourself..Thank you...
Regards!!...
  • Natesan Sabesan
    Natesan Sabesan Jul 24, 2008
    Try to contact the Dealer from whom you brought the Device for Service or Replacement..
  • 790 Answers
Hi
the best is to reformat your mp3 to software to comeback the original settings...
Thanks!!!
  • Creative Labs Master
  • 19,396 Answers
Try first taking battery out as suggested. If it does not reset it may be a fault in the lock switch, as already suggested, try blowing canned air and spraying just a small amoun on contact cleaning solution on the switch. If it does not unlock the switch must be replaced.
    Genius:
  • 1,847 Answers
Take the battery out and reboot the unit.
  • 790 Answers
Hello!!
Then the switch back end connection may be worn out!!!
  • 813 Answers
Reset the all the setting see the manual of mp3 plyer
  • sandip panchal
    sandip panchal Jul 24, 2008
    try the online support is available of your mp3 plyer try to conntact them
How to update
Before updating the firmware, be sure to verify and complete the following procedures:
Back up all audio, video, image or data files stored in the player to a secure location before changing the firmware.
All contents in the player will be lost when you install a new firmware.
Close all active applications as well as all background applications, including all media players and anti-virus programs such Norton Anti-virus.
Disable the Detector application in Creative MediaSource.
To do so, start Creative MediaSource, click on Tools, Settings, and then Detector. Uncheck the box next to Enable Detector.
Close down MediaSource.
Ensure that the firmware download was saved into the hard drive of your PC, not the player itself. Otherwise, it will report an error message Unable to lock the drive.
To check for firmware version before the firmware download, please refer to the section How Do I Find the Firmware Version on a Creative MP3 Player
To update the firmware of a Creative MP3 player, follow the procedures below.
Download the appropriate firmware from http://www.creative.com/support.
While at the site, select a region to download from.
At the download page, make sure you select the exact model of your MP3 player.
You can also select your product and firmware from the list below.
Each firmware download is accompanied by a Web Release Note under Show Details.
To find out more on how to install a firmware, click on the Show Details button at the download page, or refer to the README.TXT file if included with download.
Connect your player to your PC and check that it is installed correctly
Double click on the downloaded firmware file.
A window will appear with instructions on how to complete the firmware update.
Creative Zen Neeon 512MB/ 1GB/ 2GB Firmware/Applications Download
Creative Zen Neeon 5GB / 6GB Firmware/Applications Download
hope this helps
Oct 08, 2012 | Creative Labs ZEN Neeon 2 MP3 Player
My zen neeon mp3 player is frozen. when i turn it on, it just shows the logo and does nothing after that. What can i do ?
Leave it alone for a while, then try reinstalling the Zen Program, then plug it in, then rest it, then try to switch it on. It worked for me
Nov 26, 2010 | Creative Labs Zen Neeon MP3 Player
Free installation CD download for Creative Zen NEoon 5GB
Go to the Manufacturers Website they have them available for Download in PDF Form for Free.
Jan 12, 2009 | Creative Labs ZEN Neeon 2 MP3 Player
"PLAYER LOCKED"
Allow unit to run dead.recharge battery.turn on and push reset(small paper clip in reset hole).turn off and back on .should now work.if not format and download new soft ware at http://support.creative.com/kb/ShowArticle.aspx?sid=8451.RICHARDM69
Nov 09, 2008 | Creative Labs Zen Neeon MP3 Player
Zen neeon lock switch doesn't work
Zen neeon, lock switch doesn't work. When I turn it on it shows a "PLAYER LOCKED" icon for a short time and then turns off.
Aug 30, 2008 | Creative Labs Zen Neeon MP3 Player
Zen m wont turn on
Well, it needs to charge via USB on your computer, so plug in your zen into the computer with the creative usb cord, and let it recharge. It may not necessarily turn on if it's really out of battery, but you can tell its charging when the switch you use to turn on and off, and hold, the light is blinking. After sometime, your Zen screen on the upper righthand corner should show a little battery and be blinking green what stage it's at in its charging. When its done charging the battery icon with be fully green, not blinking, and have a little plug icon inside of the battery icon to indicate that it is fully charged--takes a couple of hours to charge.
If that does not work, check your USB cord to make sure it's not damaged in any way. If it is, you may need to purchase a new one for better connection. And if that doesn't work, then you might need to replace the battery altogether, which I'm sure, if you are still in your manufactuer's warranty, they can do for you. After it is replaced, your zen should be good as new and ready to operate.
Hope this helps. Good luck!
Jul 17, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Neeon 5gb froze at Creative logo
You firstly should make sure about you dont have some autorun virus in your player.I had the same problem and i fortunately discovered an autorun virus in my player.I cleaned it and i started it in recovery mode.then i updated the firmware.it began working.you should try that.you can find the firmware upgrade program on creatives website.Good luck.
Jun 19, 2008 | Creative Labs Zen Neeon MP3 Player
Free Installation cd download for CREATIVE ZEN NEEON 2
here are the links.....
1st link,....
2nd link....
if his doesnt work for the device you have....try searching for the absolute name....
thanks
Feb 12, 2008 | Creative Labs ZEN Neeon 2 MP3 Player
FROZEN DEAD!!
What size Zen Neeon do you have? The 512MB, 1GB, and 2GB models are Flash based and dropping them should do much damage unless you really smashed it up. However, the 5GB and 6GB models are hard drive based and dropping them from any height can be extremely damaging (especially if the hard drive was reading/writing when you dropped it). Basically, it's dependent on that to know how to continue with your issue.
Jul 27, 2007 | Creative Labs Zen Neeon MP3 Player
Zen Neeon frozen completely
Creative Labs Zen Neeon MP3 Player Logo
66 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
