You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Installing the Software and Adapter
To install the wireless-N USB adapter with custom setup:
1. Insert the Resource CD. If the CD main page does not display, browse the files on the CD
and double-click Autorun.exe.
2. Click Install the Software.
Select one of the following methods to configure and manage your wireless network:
• Smart Wizard. Allows you to manage your wireless networks with the NETGEAR
WNA1000 software and to connect securely using Push 'N' Connect.
Figure 1-1
Figure 1-2
NETGEAR Wireless-N 150 USB Adapter WNA1000 User Manual
1-5
v1.0, August 2009
- Configure network manually. Specify the settings for your wireless-N USB adapter
in the Settings screen.
- Configure automatically. Allow the Smart Wizard to automatically configure the
settings for your wireless-N USB adapter.
• Windows Utility. Connect to and manage your wireless networks using only the
Windows configuration utility. For more information about Windows utilities, see the
Windows documentation or the NETGEAR application note at:
http://documentation.netgear.com/reference/enu/winzerocfg/index.htm.
See page 1-3 of the manual:
ftp://downloads.netgear.com/files/WNA1000_UM_05AUG2009.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
