Question about JVC HD-52G886 52" Rear Projection HDTV
No sound just got dish network, the tech messed with menus and now I have a picture but no sound. how do i reset to factory settings so i can reprogram?
  • 1 more comment
  • losh2267 Sep 02, 2008
  • Anonymous Sep 26, 2008
  • couldbee May 11, 2010
    installed new bulb now i don't any screen, menu, etc. bulb works
I messed with the menus and now i have a picture but no sound
Posted on Sep 02, 2008
Just got direct tv have picture but no sound
Posted on Jan 12, 2009
  • tkneebop Jan 12, 2009
    I still can't find the answer
No graphics on the screen GUI
needs a tech to reprogram the tv ez adjusts, the parameters have to be set to their factory values
Jul 13, 2013 | Sony KDS-70R2000 70" SXRD TV
Audio but only black screen for video on WS65807
First, the set has a hard reset but it will NOT affect convergence which is stored in a separate area of the set.
Model indicated has 3 hidden menus---all accessed with the Original remote and a 4 digit code.
At your own risk:
This is a V17 chassis that was used in 8 models.
It has 3 hidden tech menus: With set on:
Option menu is 8270 enter---The Option menu reset will return all settings to factory and also will clear any glitches out of the way--it as stated can cause Convergence not to be affected.
Circuit adjust menu: (stay out as one wrong move and fatal things can happen is : 8257 enter.
Convergence adjust menu: (better than customer and SAVES adjustments made in to the DCU or digital convergence unit in the set.
keep in mind I do this here for free and have worked on hundreds of these Mitsubishi sets.
Dec 02, 2012 | Mitsubishi WS-65807 65" Rear Projection...
I have a dish network 322 will play in one room, but 2nd room it continues to try to acquire a satellite
Hey there, my name is Cheri Torres with DISH Networkcustomer service. I came across your post and wanted to see if I could help.When one of your televisions are working fine and the other is trying to acquire satellitesignal there could be a few different things going on such as a bad satelliteinput on receiver, bad separator etc. The first step you are going to want totry is performing a hard reset by unplugging your DISH Network receiver box for10 seconds then plugging it back in. If you have tried the hard reset the nextstep would be to check your entire cabling make sure all your cables are tightand secure coming from the receiver and running into the wall. After all thecables are checked you are going to run a check switch test. In order to run aCST you will need to press the menu button then 6(system setup),1(installation), then 1(point dish). Once you are in the point dish screen youwill select check switch, then on the next screen select test. Allow the testto finish then you can proceed to cancel out of all the menus. Once you are outof the menus you will see the satellite trying to acquire the signal againallow this to finish. In the case that none of these steps fix the issue youare going to need a technician to go to your home to fix this issue for you inperson. In order to get a tech set up you can call our customer service line at1-800-333-3474 or you can email me with your account information and phonenumber and I can help you get a tech set up, my email I hope you find this information useful if youneed anything else feel free to post back here or email me.
Jan 11, 2011 | DISH Network 322 DTV Receiver
I have a bell express view 6100 but the remote does not work. It appears that I should be on frequency 1 but my receiver is set to frequency 11. Is there a way I can reset the receiver to the original...
We would be happy to help you with that. We would recommend programming your DISH remote to the remote address your receiver is set to. First access "SystemInfo" at TV1, this can be done by pressing the menu button on the front of your receiver. Using the remote that is NOT functioning, pressand hold the "SAT" button until all the mode buttons at the top of the remote light up. On the number pad, enter the remote address we want, in your case this would be "11", press the pound (#) button, then finally press the record button 3 times. After re-addressing the remote you should be able to use the remote to exit the menus. We hope these steps get your remote working. Thanks for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Nov 03, 2010 | DISH Network IR Remote Control
My dvr-625 won't turn on. I have reset it and unplugged it several times but all I get is a single green light that lasts maybe 20 seconds. It sounds like the fan or something is constantly running. It's...
If you havent set up an appointment yet, dish network receiver dont always run well off of power strips no matter how fancy they are, it has to do with the voltage pull off of the LNB, The LNB is the big white thing at the end of your dish. Chances are that your receiver has gone bad due to over heating or rough shipping, you can set up an appointment or call dish tell them the receivers cutting off they will mail you one and send you the postage for you to mail back the other one.
Aug 29, 2010 | DISH Network DVR-625 DTV Receiver /...
EchoStar dish network remote control #132577 will not reset
This is hopefully resolved by now, but I do have some simple steps to give you if you have any questions. Follow the link below, it will walk you through getting the remote set up. The post is not too detailed on exactly what is going on, but to me, it sounds like you want to get the remote reprogrammed, and the link below will help. I do apologize if I interpreted it wrong and if I did so, please post back.
Becki Barned
Jul 09, 2010 | DISH Network IR Remote Control
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
No sound
Look in the menus for a setting to turn the speakers on and off. Make sure there isn't a switch on the back to turn off the internal speakers.
May 24, 2008 | Hitachi 61HDX98B 61" Rear Projection...
Reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Apr 03, 2008 | Xerox WorkCentre M-24 Color Copier
JVC HD-52G886 52" Rear Projection HDTV Logo
185 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
