Question about Frigidaire FRS26KF5C Side by Side Refrigerator
Frigidaire FRS26BH6CB0 ice maker only crushes
Recently our Fridigaire ice maker only crushes ice.  The fridge is about 4 years old.  I recently changed the filter out and it seems like the issue started about the same time or maybe a little before.  Have you run into this one?
  • Anonymous Aug 19, 2008
    we have the same problem. Our ice machine only crushes ice. With the light lit on cubed or crushed it still only crushes.
  • Anonymous Sep 28, 2008
    I also have the same problem, it only crushed ice! i tried tawing out the whole freezer, cleaning the ice tray, checking the ice oger and couldnt not find anything visually wrong and i am clueless on this, I want to get it fixed because the only wau to get ice cubes is by opening the door and reaching for them
  • 1073 Answers
SOURCE: Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Posted on Apr 17, 2008
SOURCE: ice maker will only make crushed ice
There is a rod on the back of the ice cube bin. It goes below a plastic slide in the back of the fridge. If yoiu pull the bin out and it does not engage right, you will be 'stuck' on crush. Pull the bin part way out and see whether the rod is going below or above the horizonal rung in the rear. If it is above, rotate the metal control until it will slip under the rung.
Posted on Apr 17, 2009
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
woodchuck789
  • 4070 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Jun 07, 2009 | Refrigerators
Ice dispenser only dispensed crushed ice, not cubes.
there is a metal rod that sticks out the back of the ice maker bin, it has a spring around it. it needs to fit into hole in the back of the fridge.
May 17, 2009 | Frigidaire PLHS269ZD Stainless Steel Side...
My ice maker crushes all of my ice as it comes out the door. Help me - I'm strictly a cube kind of girl!! Cindy ( I've already tried to push the "crush" button and then the "cube" button again. The...
unplug the fridge 2-3 minutes and see if it resets the computor to make the ice control work normally again. You can also open up and get the cubes out cheaper than having it repaired. Sorry about that!
May 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker will only make crushed ice
Apr 17, 2009 | Frigidaire Refrigerators
Ice maker is crushing ice when cubed ice button is on
The problem is in the selector switch itself. If it is a touch pad, you will have to reset the control board by unplugging the until for 3 min. if its a physical switch, it may be faulty and will need to be replaced.
Good luck. please rate my answer as a fixya!
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice build up on fan
problem is most likely caused by water overflowing from ice tray and then freezing to motor, hold light switch in and see what happens when tray fills up. Regards Advisor
Feb 08, 2007 | Frigidaire GLRS237ZA Side by Side...
Frigidaire FRS26KF5C Side by Side Refrigerator Logo
95 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
