Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
What is the cost to call Sears to change the control board?
My dishwasher has the same problem - stuck on 1 and starts on 13. The first time it happened, I switch off the power at the power box, then, switched on, it worked for a few weeks. This time, the power reset doesn't work anymore. I think it is the loose connection on one of the wires.
Doesn't worth to open the dishwasher and solder the wire by myself (used to be an electrical engineer), or call Sears to let them to swap the control board? Please advise!
  • 54 Answers
Sears will charge about $65 for coming out and about $80 to install total = 145 for labor and trip charge.. module will be about 140.. total about $300 for Sears...
Posted on Jul 28, 2008
My Samsung dishwasher will not stop draining. I cannot stop it, except by turning the breaker off. When I turn the breaker back on, it continues. Help!!!
It is stuck on a particular cycle. If electronic unit, see if there is a reset switch on unit. If not check out with samsung for hidden code to do so. If reset is unsuccessful you may need a controller/control board.
Sears has all sorts of parts for appliances.
Sears Online In Store Shopping Appliances Clothing More
Sep 16, 2017 | Samsung Dishwashers
Lg washer 1832c now power from switch to start but has power to the circit board
Hello Jerry;
My name is Peter. I am a retired field service appliance technician.
If you do not have lights on your display, then I am afraid it is your main control board. You have a old unit and the control board is no longer available through Sears. You can purchase it through Amazon for $94.00. Part Number 6871EC2025E. If you elect to replace the board you will receive it in a silver anti-static bag. Before touching the board; GROUND YOURSELF BY TOUCHING BARE METAL WITH YOUR HANDS. STATIC ELECTRICITY WILL KNOCK OUT THE BOARD. You may want to purchase the board, go into the Sears Home Services website, print out a 10% Off Service coupon, and call sears to schedule a service call.
Rule of Thumb: "If the repair cost is 1/3 or more than the original purchase price, then buy new".
If your display lights are on, then:
1.) Bad Door Latch - Your unit will not run if the control does not get a signal that the door is closed.
25396209-azn3vdefrt5enyqdbzatir1e-4-0.jpg Part #: 6601ER1004C Cost: $52.00
2.) Bad Drum Rotation Sensor - This will shut your unit down.
Feb 02, 2015 | LG WM-1832C Front Load Washer
Hello, we have a Kennmore ultra wash model 66513482k900. The problem is it will not run through any wash cycles at all. It will not do anything, we can select nothing on the panel. We have replaced the...
The symptom your describing certainly sounds like this is a fill overfill circuit problem. The fact that you can only drain the unit and nothing more points directly to a fill overfill problem.
If the overflow switch is activated that is exactly what the unit will do. The overflow switch is item 11 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66513482K901/0582/0130000/K0908008/00006?blt=06&prst=&shdMod=
(PART NUMBER: 8268909)
Additionally if the float is stuck in the UP positon from food particulate build up on the stem it will not fill with water ever. The float assembly is item 13 of the above link. You can clean up the float assembly and the float switch most of the time and get the unit to perform normally. Occasonally parts are required but on a 2 year old unit I seriously doubt either part has failed. Just clean them up and test again. I think this will resolve the problem.
I just have issues with Sears in home service not even considering either float assembly or the overlow switch as the most probable cause of your symptom. In all seriousness if Sears was the reason for having a control panel change you have the right to ask that the part be removed and your original control panel re-installed. Your money and labor expended installing the control panel should be refunded refunded.
You really need to get in touch with the Sears Service manager and tell that person you want a competent technician that will correct the problem. I.e. do not send the previous tech out for any reason other than to reinstall the old control panel. After that... send someone else but fix it. Had you called me and I had one of my techs change a control panel that did not fix the problem the tech would be working that job for free..... The only thing you would be charged for on a call back would be labor to install any additional parts and the cost of that part. NO SERVICE CALL charges on a call back. (Just my 2 cents)
Check the float switch POWER REMOVED... by gently raising and lowering the float. You should hear a click near the top of the float travel and again as the float lowers. The over-flow switch works in the same manner. Clean up the stem on item 13.... below link and it should work.
http://c.searspartsdirect.com/lis_png/PLDM/K0908008-00006.png
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Kenmore Dishwashers
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
7 year old dishwasher motor needs replacement
No one is going to do anything for you at 7 yrs old- maybe 13 months, but not 7 yrs.
Nov 27, 2008 | Dishwashers
Electronic controls don't count down properly
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Nov 20, 2007 | Bosch SHU5315UC Dishwasher
Bosch dishwasher stuck on "1"
YOU MAY NEED A CONTROL BOARD OR A HEATER. THERE IS A CONNECTOR WITH A RED AND GRAY WIRE, THE RED WIRE IS THICKER THAN THE OTHER RED WIRES. IF YOU HAVE 120 VOLTS ON THERED WIRE THE CONTROL IS GOOD. YOU NEED A CLAMP ON AMP METER TO TEST TO SEE IF THERE IS AN AMP DRAW ON THE RED WIRE WHICH WOULD TELL YOU THE HEATER IS WORKING
Nov 27, 2006 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Apr 14, 2006 | Bosch SHU5316UC Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
119 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
