Question about Maytag MSD2756GES Side by Side Refrigerator
Refrigerator warm my maytag refrigerator model #MSD2756GES is not cold on the refrigerator side i don't here a fan blowing like i use to
  • Anonymous Jul 20, 2008
    I checked the fan in the back and found the fan had something caught in it and had stopped.
  • fulghumml Feb 20, 2009
    This sounds like the same problem we are having. The unit seems to run all of the time and the fridge side is not as cool as it should be. Some weeks ago there was a periodic noise that might have been a fan blade hitting something. The noise has gone, but that might mean the fan is stuck on something. Will check that tonight.
  • Maytag Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorrefrigerator warm - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Could i get the scamatics or diagram
MSD2756GES MAYTAG SIDE-BY-SIDE REFRIGERATOR ...
www.searspartsdirect.com > Kitchen Appliance Parts > Maytag Parts
Download Manual for Model MSD2756GES MAYTAG SIDE-BY-SIDE REFRIGERATOR.Sears PartsDirect has parts, manuals & part diagrams for all types of ...
Sep 22, 2015 | Maytag MSD2756GES Side by Side...
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
What would cause the freeze to be cooling normally and the refrigerator side to be at a temperature of 55 degrees?
all it does is the freezer gets cold,the evap fan blows cold air from the freezer into the fridge section so if the freezer is fine,check the air ducts in the fridge section,if a package or something is blocking the vent on the bottom it will get warm or also on your model you have a damper on the top where the air blow into the fridge section from the freezer,you have an electronic damper,there's a door that opens and closes to let the air in,when it's cold enough the door closes when it gets warm the door opens so either the damper is bad or the computer board that operates it is bad,also check the packages in the freezer,if you see frozen water droplets on the packages or ice on the shelves the door could have been left open and the air ducts freeze so no air can pass through,you can hit the air ducts with a hair dryer to melt them out but be careful,don't keep the heat on one spot for to long,you can damage the ducts,also when you open the freezer door you should hear the fan blowing,if not you could have a bad evap fan motor and the air isn't blowing over to the fridge section,the damper is like 45 dollars and the computer board is around 120 dollars,you can go onto the sears site,put your model number in and look at the controls and you can look up the parts.http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MCD2257HEB/3048/0165000/M0703130/00006?blt=06&prst=&shdMod= copy and paste.open the freezer door,listen for the fan no fan bad motor,if the fan is blowing either the air ducts are frozen or you have a problem with the damper or board that operates the damper,you might want to call in a tech for this if it is the damper,it's a little tricky to do this job but that's up to you.good luck and i hope this helps you out.
Sep 24, 2011 | Maytag MCD2257HE Side by Side Refrigerator
Fridge stopped working/ freezer still works great?
the freezer works ok..this is where the cooling unit is..so, if the freezer works ..its not blowing or allowing air to flow into fresh food area..if its missed its defrost..it will not allow air to go into fresh food area and you need to remove panel and defrost coils ..or see if blower is working...check for bad heater or defrost thermostat or what controls defrost ie timer or board
May 20, 2010 | Maytag MSD2756G Side by Side Refrigerator
The refrigerator side does not keep contents cold. I have it turned up high and there is no improvement.
Check the fan that moves air to the refrigerator side to see if it is working. You may have to listen closely as you open the door as some of then shut down when the door is opened. Also defrost you refrigerator for 24 hours. You may get water on the floor as it defrosts if it is really bad. Then restart the refrigerator and check that the fan is working and it is cooling.
Nov 12, 2009 | Maytag MSD2756GES Side by Side...
Warm refrigerator
I had the same problem with my msd2756ae. We had been using the blow dryer, removing the rear panel in the freezer section, etc.
We replaced the adaptive defrost control board. Solved our problem. It's an easy replacement, located in the refrigerator section, top right---behind the temp. control slide. The hardest part is removing the top panel that holds the temperature slide. Then it's "pull and replace".
May 18, 2009 | Maytag MSD2756GES Side by Side...
Fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Feb 17, 2009 | Maytag MZD2766GES Side by Side...
Fan runs but no cool air on both freezer side and cold side
If you hear the compressor try to start then click off, you probably have a bad compressor or a bad relay. If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge. The relay is only covered for a year. With it being a Maytag, I bet it is compressor. There have been a few models with control board problems that have caused this symptom, but that's not likely to be your problem.
Oct 06, 2007 | Maytag MSD2756GES Side by Side...
Maytag model RTC17A
how is freeezer side doing? Do u have any frost build up in freezer back wall and is you fan in freezer blowing?
Aug 31, 2007 | Maytag MSD2756GES Side by Side...
Maytag MSD2756GES Side by Side Refrigerator Logo
385 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
