Question about Hampton Bay Heating & Cooling
Have a hampton bay 24000 BTU AC. Smelled burnig behind control panal. Opened it up found what seems to be an overload switch burnt through.. Leads go to capacitor terminal C & Herm. I changed the capaitor had the control switch on off. Kicked the breaker on in service panal & it blows like a dead short. I'm thinking the overload switch is similar to a fuseable link. Which if burnt through should just be open, not dead shorting AC with switch on off position. Any ideas what to check. Thermostat switch,control switch, leads to compressor etc all seem to be ok & not burnt. Can I bypass the overload switch to see if unit runs.
  • navy11 Jul 20, 2008
    • Burnt overload switch
    was cut off before i could start my live chat.
  • 3 Answers
I checked wiring on my other 17,000 BTU Hampton bay AC & noted there was no overload switch wired into capacitor. So i just removed the burnt out overload switch which was causing a ground & blowing breaker. I noted it was not wired in between the compressor circuit but just attached to the compressor terminal & common terminal on capacitor. I guess it is a sacrafise type device that saves the compressor from burning out on overload. Anyway The AC worked fine with the burnt overload switch removed. It has been runnning 2 days now with no problems. I however did replace the capacitor with a new one. You can use either an oval or round capacitor as there is ample room. Just make sure your cap. values match old one. I will probable try & purchase a new overload switch if possable & install it at a later date, for the extra protection.
Angelo V.
Posted on Jul 21, 2008
Trying to find manual for a Hampton Bay ceiling fan. I have two. Tag on fan says model: AC-552AL, Item# 154620 NN, Another sticker on fan says 05/02 E192641 UL Listed CEILING FAN 47BF
You should find what you need here:
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Remote-Wall-Controls/Hampton-Bay/N-5yc1vZbvmuZp4
Apr 03, 2017 | Hampton Bay Dryers
Where is the dip switches for the remote control on a Hampton bay fan.
If this is anew fan it will not use "DIP" technology.
Feb 09, 2017 | Hampton Bay Dryers
What tonnage is it
not sure what you want so i will give a general answer.
tonnage is equal to BTU ...
so it you have a....
12000 BTU that's a 1 ton AC
24000 BTU that's a 2 ton AC
36000 BTU that's a 3 ton AC
and so on and so on just look on the tag for the BTU's
Feb 01, 2016 | Heating & Cooling
I have a Hampton Bay ceil fan model # AC-552 "NN" and the serial # 000371. We had lost power in our neiborhood a while back and was use the generator and when the power came back on our fan didn't work....
Hampton Bay is an exclusive brand of Home Depot. They would be the ones to help you with that. BUT .. from my experience I would say that the cost and trouble of getting and replacing the motor in that fan would be easilly rivalled by the cost and ease of buying and installing a new fan all together.
Please Vote !!
Jun 02, 2010 | Hampton Bay 52 In. White Redington...
I HAVE A HAMPTON BAY MODEL AC-418 CEILING FAN. IT
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The fan unit itself is manufactured by AirCool 800-896-4908
May 10, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Blown capacitor on 4 year old ac hampton bay is
Not common, keep in mind compositor work almost like a fuse but restrict certain amount of voltage to flow through, power surge or unit overload from AC compressor kicking on and off can cause the resistor to fail; its parts of electronics working. My AC unit trip my main fuse box once in the great while, nothing surprises me when it come to electronics.
Jul 16, 2009 | Hampton Bay Heating & Cooling
HOW TO CHANGE DIRECTIONS OF BLADES ON HAMPTON BAY MODEL #70226
There is a switch on the side of the fan motor housing. Slide it the opposite way to reverse it. Make sure you wait until the fan comes to a complete stop to do so. Never reverse it while it is running, you could overload the motor and ruin it.
I believe they don't put the reversing switch on any remotes for that very reason.
Sep 15, 2008 | Universal Remote Control Hampton Bay...
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Heating & Cooling Logo
307 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
