Question about Cobra microTALK PR 3500-2 DX VP 2-Way Radio
Cobra #3850 owners manual .
I purchased above and did not get a opeators manual.
can you down load one to me?
  • 667 Answers
Hi - buddyo - this link should be what you're looking for. If not let me know. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://cobra.com/downloads/manuals/Cobra%20Manual/GMRS_MANLS_3.18/PR3850WX_MANL.pdf
Jeff
Posted on Jul 20, 2008
Need a Cobra 19 LTD II CB Radio Owners Manual
Did you buy it from a dealer or a friend? From the dealer it should have been in the box and from a friend you outta luck.Do a google search for one ,you should find it that way.
Apr 05, 2014 | Cobra Radio Communications
What battery is needed for Cobra Model #PR3850?
just have to wrap a bit of tin foil over the bottom of one battery and use normal nimh rechargeables. The Cobra's have a seperate circuit that must be made to differentiate between normal AA and rechargeables. The OEM battery has an exposed metal ring on the bottom of the battery. If a normal AA is put it and allowed to attempt to charge, it will start a fire. If you look, there is one contact at the negative end of one battyery that must be made for it to allow to charge in the base. You could scrape away the plastic, but a wrap of tin foil did the trick for me.
Oct 26, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
How do i turn off the beeping from cobra microtalk 2 way radio
  1. Press the menu button to scroll through the features.
  2. When it says "set roger beep on/off" press the up or down arrow to turn the roger beep off.
  3. Now press the talk button to return to stand by.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 14, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
Just need a users manual on line
Right click here,
and click on "save link as" to download the manual
Jul 11, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
Is sthere an instruction manual available online. Thuis unit is about 10-12 years old and rarely used
Your manual can be found here:
https://www.cobra.com/downloads/manuals/PR3850WX_MANL.pdf
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
I lost my manual. Can I download a basic guide for free? Cathie
Yes, Cobra has the user manual for the PR3850WX available for download HERE
Oct 13, 2010 | Cobra Electronics microTALK® PR 3850 WX ...
I have 5000W inverter & hooked up to my battery power supply.display is saying "l up" .i think it means lock up.i was wondering how to unlock.
Could it be L.U.P. it's really L.V.P. but the V looks like a U. If it is it's low voltage protection. If the incoming voltage drops below 10.5 volts, it begins to flash. If the voltage drops below 10 volts it shouts down. If you supply it with 12 v it should restart. If you don't have manual you can view/download one from www.cobra.com.
The low voltage could caused by low battery. Poor connetions. Wire too small for load being supplied.Inverters over 1500 watts will require #1/0 or larger cable, in the shortest possible length. NOTE: Cable size recommendations may vary among inverter brands and models; check the Owner's Manual for the model you purchase before you buy the wire for it.
Jun 21, 2010 | Cobra 2500w Power Inverter
Owners manual
Is it the Cobra Nav One GPS 5000? If so, click here http://tiny.cc/AVYT5 and then click on: View Manual.
(This may take a minute to load.)
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Jan 31, 2010 | Cobra Gpsm5000 Car GPS Receiver
Cobra microTALK PR 3500-2 DX VP 2-Way Radio Logo
304 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
