First..-DO THIS NOW - Change the oil and filter, change the transmission fluid and filter.. grease ALL the fitting you can find... make sure both battery cables show NO signs of corrosion..(they WILL corrode from the inside and not show on the outside!!).. clean all terminals and clean the battery terminals... a little grease on these prevents corrosion...
SOURCE: when i pass thru the water my dash board have a
Hi it looks like your are having an electrical issue, inconsistent voltage, or bad grounding.Have it check first by auto electrician to check the wiring to really isolate the problem. .Thanks
