Question about Navman GPS
I suspect my charger socket on navman has a fault was intermitant now it wont charge at all, output from charging unit is ok output is 6v dc
Hi Rob here i solved prob thanks side contact was not making connection for recharging plug managed to manipulate it so it is making good connection now..
Regards Rob.
Posted on Jul 21, 2008
Battery won't charge
If the battery wont charge the item will need a service engineer to test it. I am not sure of the particular model but there is a possibility that either the charger itself is at fault OR the charging circuit has either a diode or capacitor damaged.
If the charger plugs into a 240v socket in the house have the charger checked to show voltage is being output by it.
If it is then how old is the battery on the scooter? does it need replacing? have a voltage test done.
If both the battery and wall charger if there is one is OK then I would say another part of the vehicles circuitry made be at fault and suggest you have it looked at. .
Apr 24, 2016 | Pride Celebrity X 3-Wheel Electric Scooter...
I bought this camera only a couple of months ago. I used it at a maximum three times, but at late it wont charge. I have multiple USB chargers and have used them all, but still wont charge :(
Hi, Check the connections for tightness and use a volt/ohm meter to check for charging voltage. Anywhere between 6v and 12v. If you suspect charger, replace with same kind and Voltage output.
Also check battery(s). replace if dead. After many battery uses. They can have an internal discharge and will not work properly any more.
Good luck.
Jun 06, 2015 | Olympus VG-170 Digital Compact Camera -...
6 Volt dc 4w charger for Omron blood pressure unit
You can use a multi voltage mains adapter for your Omron. These are available at electronic stores ot on the Internet. Make sure it is a DC adapter and switch to 6 volts also make sure the power connector is set correctly to the polarity of the Omron power socket.
Nov 30, 2012 | Omron Health & Beauty
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
My Toshiba Portege M200 just stopped charging and wont even turn on? Is this the battery? Or what? The charger will be plugged in the wall and plugged in the laptop but nothing?
Try removing the battery and see if it will boot without it
Then check the caharger, charging light should be green and steady on the charger itself
If it is flickering, it meand power is not making a circuit, test charger jack with a DC volt multimeter with one probe to the outer side (earth) and one on the inner (positive). If this is ok, check the charging socket is not loose (if it is, will need replacing).
After that, suspect the power strip or charging / powerboard is dead on the motherboard
Mar 22, 2011 | Toshiba Portege M200 Tablet PC
Navman won!t charge from in car charger or mains adapter but will charge from garmin in car charger
Your Navman will not run in car unless the output on the charger is 1000ma or 1a. you need to buy a genuine charger, motorola phone chargers do not have the output to run the unit
Jul 22, 2008 | Navman F20 GPS Receiver
Navman N40i Not charging in car
Does the car charger cord plug into the cradle? or just straight into the unit (despite resting on the cradle) ? Do you know if anything else charges via the car charger?
Mar 15, 2008 | Navman NavPix N40i GPS Receiver
Battery Charging Navman S90i
The problem is that most of the chargers have the output of 5V/0.5A. The charger for NAVMAN (C30 in my case) has 5V/1A. And that is causing the trouble. The GPS is undercharged and is switching off itself. Buy one which specify the output power: 5V/1A. Hope I solved your problem
Feb 04, 2008 | Navman F20 GPS Receiver
GPS Logo
69 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
