Toshiba 42h81 My toshiba 42h81 tv went black after a clicking sound there is no sound the power light is blinking . I unpluged the tv and pluged it agan but no solution what could be wrong
  • jnkunec Jul 20, 2008
    The switch on the tv does nothing the remote does not work cannot use it
    Brigadier General:
  • 3,614 Answers
Have you try to switch it on using the contol on the tv..?
Posted on Jul 20, 2008
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
May 27, 2009 | Toshiba 42H81 42" Rear Projection...
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Power light blinking
I have a Toshiba 42H81 that has the power indicator light blinking and the TV will not turn on
Oct 14, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81
Won't be any cheaper if you go looking and you'll probably get sold some chinese knock-offs anyway... It sounds like you'll need to replace the convergence amps, both STK392-110 Sanyo originals. Also the tech will test the yoke return path circuits and the resistors therein... Likely s/he'll find that one or more has change slightly in value and change those as well for a more reliable repair...
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Sep 20, 2008 | Toshiba 42H81 42" Rear Projection...
TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 Blinking on and off light
Very common problems with this TV set. Toshiba even has a technical bulliten on this and several other models of tV set. The negitve terminal of C809 and C810 need to be soldered, as there are no eyeletes in the printed circuit board. This problem could also take out the fuse, F860. Replace if necassary. Good Luck
Mar 31, 2007 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
