Question about LG LWHD1800R Wall/Window Air Conditioner
Central air I run two central air systems the one upstairs was working fine, but not the fan keeps running the central air shuts off but the fan continues.. Is this my theromostat
  • 143 Answers
Most thermostats have a setting for the fan called, "manual". That keeps the fan on continuously. The electronic thermostats can fail in a "fan on" condition. That would require a new thermostat. I also saw one air conditioner with a fan relay welded "on" by electrical surge. That would require a new relay.
Posted on Jul 22, 2008
How do you turn on only the fan to cirrulate air through the house in the summer?
Hello Wendy,
You didn't say what kind of system you have, so we'll assume you have central heating and air conditioning.
There are a few things you can do to keep air moving in the house with your central system. Depending on the brand of system you have, you can turn the heat/cool switch on the thermostat to "off" and turn the fan auto/on switch to "on." This will disable cooling and heating but allow the fan to run continuously.
You can turn the thermostat up to a temperature far above what you would normally use in summer and turn the auto/off fan switch to on. This will force the fan to run continuously. The cooling will still work when the temperature in the building exceeds the higher set point.
These steps will work on most systems but if you have one of the new "NEST" or other internet-connected temperature control systems, you can refer to the operating instructions to see what your options might be.
Note that leaving the fan on all the time will result in higher electrical costs, more wear and tear and you may have to clean or change the furnace filter more often.
You might be better served by purchasing a free-standing floor type "tower" fan and placing it in the room you are in most frequently.
You could also use (or install) ceiling fans.
Jul 19, 2017 | Heating & Cooling
Fan continues to run in the off position?
The contacts in the switch are welded shut (if this is a portable unit). On a central system, the fan relay contacts are welded shut.
Oct 06, 2013 | Amana Quiet Zone 12M12TA Air Conditioner
I moved into a place that has a MasterCool Evaporative Cooler on the roof. The ownstairs is quite comfortable so I really only need to cool the 2nd story.... it seems as if all the cold air settles...
jbrown - Hot air rises, Cold air falls. If you have ceiling fans upstairs, turn them on to run counterclockwise at highest speed you can stand. Make sure all the windows are closed upstairs. The ceiling fans will help to keep the cool air upstairs and pull some from downstairs.
If you don't have ceiling fans, invest in a box type fan that you can place at the head of the stairs (that's the top of the stairs) run it on HIGH and it will act like an exhaust fan, by pulling cool air upstairs. It may take a while, but it will help cool the upstairs to some degree.
Hope this helped you. Please let me know. Thanks.
Jun 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
I had a Honeywell Thermostat RTH8500 installed by a pro to run Heat / Cool electric heating WITH central air conditioning. Problem : When running on cool Fan on auto ,it work OK but sometimes when the...
Is this a new hvac system? A new furnace can work differently than your old one. Does it shut off after a minute or two or continue to run? If it continues to run then call that professional back and let him fix it. If it shuts down after a minute or two then it is a feature of the new thermostat to squeeze all of the cool it can from the a/c coil and ductwork.Some of them have settings that you can adjust for blower delay on and off, read the manual that came with the t-stat and see if it does.
Jun 16, 2011 | Honeywell Heating & Cooling
I have an Aprilaire 1750 installed inline with my upstairs central air system in the attic. The unit's ducting appears to be installed as indicated in the installation manual, but when the unit is running...
Your dehumidifier is likely working correctly. When operating and removing moisture, a dehumidifier will supply warm/hot air to your house. Your dehumidifier moves less air than your A/C, so your supply ductwork in your house is oversized for the dehumidifier. This will lead to uneven feeding of your supply duct branches with just the dehumidifier operating.
Since your dehumidifier is installed in the attic, make sure that the ducting connected to it is well insulated. Also make sure that your dehumidifier cabinet is insulated. These actions will help prevent heat gain from the hot air in your attic.
Is your dehumidifier bringing in fresh air from outside? If the outside air is hot and humid, the dehumidifier will supply warmer air to your home.
Some people run their A/C fans continuously to help with the air distribution, but this is a bad idea since it increases energy usage considerably.
DryDog
Aug 06, 2010 | Aprilaire 1700 Dehumidifier
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Jun 03, 2009 | Heating & Cooling
Fan is still running in house constantly
Check your wall thermostat to make sure the "fan" switch is in the "auto" position. If it is set at the "on" position, the indoor fan WILL run continuously. Not really enough info as to what type of split system you have. Gas? Electric? Heat pump? Oil? Wood? Newspapers? See what I mean? Is it variable speed? Do you have a "special" thermostat for certain operations? Does your system incorperate inverter technology?
Apr 24, 2009 | Ruud Central System Air Conditioner
The fan on my central heating system keeps running
IN MOST PROGRAMMABLE STATS THERE IS A FACTORY DEFAULT PROGRAM.IT COULD BE
RUNNING IN THAT MODE.FIRST,CHANGE THE BATTERIES IN THE STAT.ALSO,THEY HAVE A
RESET BUTTON ON THE CIRCUIT BOARD.TRY THAT.AND,BY THE WAY,YOU ARE NOT SAVING
ANY MONEY BY DOING A TEMP SETBACK.THE HEAT SYSTEM WILL USE JUST AS MUCH
FUEL EVERYDAY TO RECOVER THE LOST HEAT DURING THE SETBACK PERIOD.ALSO,THE STAT COULD JUST BE BAD.
Mar 05, 2009 | Honeywell Programmable Thermostat Heater
Air conditioner/furnace squirrel cage fan remains running when th
Ensure you don't have a short in your therm wires. Disconnect them, if the furnace continues to run, you have a lockout problem at your furnace. When the motor on the fan fails, it wont run. Check for led codes on the control board. If you don't have led codes, turn off the power to the furnace at the breaker, and watch the unit. If nothing happens, connect the thermostat. If nothing happens still call for heat. Let the therm run through it's cycle, and if the bower runs continuous again, let me know we can walk through that situation.
Dec 05, 2008 | Ruud Central System Air Conditioner
Heating & Cooling Logo
236 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
