It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Anytime the extension stops working, it is generally caused by a dead battery (90+% of the time). It is occasionally caused by the extension base not charging the battery. Try to pay attention occasionally to the charge status on the extension phone.
If the line indicator lights worked before changing the batteries, check the polarity of the new batteries. The lights should only come on when the line is in use by someone else.
By jim_giardine on Jan 03, 2010 My
parents have had their Panasonic KX-TGA101 for a little over a year and
it just stopped working. It no longer rings when a call comes in.
Plus when we try to answer a call or place a call all we get is a busy
signal both auditory and in the display window. SOLUTION: you might want to change a new phone line, that's maybe the culprit, most of the time is the phone line is worn out first due to too many reasons.
Hello amalia, I think what happened is just software crush .. anyway, please contact Panasonic costumer-care Click Here or visit nearest Panasonic Service Center, you can know where is that by clicking here Thank you for using FixYa.
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
