Question about Sony Televison & Video
Phillips TV I have a 3-4yrs old Phillips flat-panel TV that is HD capable. Last week I turned it on and the screen had a fuzzy blue color with soft white lines. The picture was still slightly visible but mostly obscured by the blue aura. I tried adjusting everything I knew to do by no change. Is it over? Time to go to Best Buy? Thanks in advance, Daniel
  • 2,294 Answers
The failure is in the video circuitry but it could also be in the power supply of the TV.
I would say that if this is something you could do to fix the TV yourself, is worthy but if not it might be better to save the money towards a new one. I would also suggest to try to buy the extended warranty if you can because today electronics devices do not seem to last for a long time.
Posted on Jul 20, 2008
    Genius:
  • 1,847 Answers
Did you try resetting the tv to factory settings
    Genius:
  • 1,011 Answers
Dear Sir/madam,
You have defective filter capacitor/s in the vertical circuit. Or defective solder connections on the pins of the vertical ic.
If you can bang it on the side & get the picture back up, then you probably have a bad connection in the vertical output circuit.
It should just require resoldering the printed circuit board & I would guess right at the output I.C.. Replace the IC with authorized service centre.
Thanks
Good luck
Don't forget to rate the solution
New 60ph6700 hd 3d tv /watchind hd sports fuzzy grass and background/once in awhile lines run through screen/its only two wks old??
Anything new has a chance of failure the first month or so from cold solder joints on circuit boards. If it passes the first month it may last 8 or 12 years. Send it back under warranty.
Nov 29, 2013 | LG 60" 6700 Series Plasma HDTV - 60PH6700
The tv gets really fuzzy and changes color after watching it, but i think it has something to do with the wire ports because if i hit menu while its all fuzzy, and when the menu comes up it looks normal,...
check cable connections:
1. cable from wall to tv or to pvr. properly connected?
2. yellow,red and white in correct ports?
3. if HD, use green, blue and red to respective ports.
4. is remote properly sync to tv?
5. if no 3 above, get HDMI cable and connect to pvr.
Aug 12, 2013 | Westinghouse LTV-32w3 HD Television
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Samsung tv won't turn on
do u hav e back light , if u do u may have a bad signal board ,need model #
Nov 07, 2008 | Televison & Video
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Funai tv
Open the back cover and check any fuse blow in Y Sustain board or Z Sustain board. If you do find the fuse gone, replace the board. Good luck!
Jan 25, 2008 | Funai F42PDME 42 in. Plasma Television
My tv screen goes green and then turns off by itself
mine does that to but when i turn it on its blue and in like 5sec. turns off by its self
Nov 09, 2006 | Premier Mounts Universal Flat Panel Wall...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
