Question about Toshiba Televison & Video
My 42h81 toshiba lcd tv went black after a clicking noise with my power indicator light flashing there is no sound I unpluged the tv and then repluged it but no result. What could be wrong and how much to repair it?
  • 9 more comments
  • jnkunec Jul 20, 2008
    You have offered no solution Just give a possible reason why my toshiba 42h81 went blank after a clicking sound with no sound and the power light is blinking .I unpluged the tv overnight and pluged it agan but no solution
    My 42h81 toshiba is a lcd tv I donnot believe it is a rear projection one
    If the convergence ic are gone wouldnot your sound continue to work
    I will restate my problem as clearly as possible my toshiba 42h81 lcd clicked and went black with no sound or picture the remote does not work and the only thing that works is the red blinking light on the power source the manual power switch does not work nor do any of the options on the remote.
    where do you find the f850 f851 f470 and f890 fuses for my toshiba 42h81 tv
    are there any fuses on my toshiba 42h81 tv where are they found
    Please answer the previous questions
    I already tried unpluging and pluging it after soom time 8 hrs. just a clicking sound to start of and then the red light in front of the tv blinking and none of the switches in front working nor the remote
  • jnkunec Jul 21, 2008
    my 42h81 toshiba tv made a clicking sound and then went blank with the front power red light blinking no sound no remote only way of stopping the red light was to unplug Could it be a fuse where is it ant ideas thanks
    From the last comment I have to conclude that none of the answers provided any insight into anything not even if the tv has fuses and where they are located
    Ofcourse its a hardware problem still havennot answered the question if the tv has fuses
  • 10,594 Answers
Such symptoms comes only if Power Supply becomes bad or LCD Panel got defective. In either case, You have to contact concern service center for proper repair. Its not matter to handel it at home by yourself.
Posted on Jul 21, 2008
  • Shahid Electronics
    Shahid Electronics Jul 21, 2008
    Attention to all who says Convergence Problem, Let me tell one thing, there is NO Convergence Section in LCD TV.
    Genius:
  • 1,447 Answers
Hi-
Hi chances are you are having a bad mainboard for your TV, you can only access it by opening the TV so that you can check on it, before you do that check the warranty status of your television first so that you wont void it if you open it up, and suggesting that you have it check by an experienced technician. Thanks for using Fixya!
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jul 21, 2008
    Hi-
    No it doesn't have one that you can replace instantly since the fuse is on the board connected.
    It doesnt have a fuse
    Genius:
  • 2,035 Answers
This is hardware failure in your Tv , you need to give to local service center for repair it will cost you $150 to $500 depending upon the problem......
Good luck.....
    Genius:
  • 1,226 Answers
You TV now require a TV LCD specialist to personally check all the parts inside. My final diagnose is the power input of the tv cannot regulate the correct voltage to project the picture on the screen. so if the power input is in correct out put you need to isolate some parts and test it using multimeter or any specific tools for testing in the capacitor, regulator and some other resistor and diode. when resistor burnout means that there is a short circuit either in regulator..
But for most effective solution is to let check the TV personally by electronic tech.
melnavz
  • Emelio Navaja
    Emelio Navaja Jul 22, 2008
    Bring the LCD to the qualified electronic repair for best result. or call TV service center in your area.
  • 2,071 Answers
Power Supply Details
The defective power supply module will cause the following symptoms:
*No Display and no Sound, Then Power indicate light changes from Green to Red.
No technical skills require to perform the replacement. Anyone can do it. It is easy, economic and convenience to repair LCD TV
Click this site for replacement power supply assembly;
www.MONISERV.com
Good luck and thank you of using fixya;
  • LORETO LACARON
    LORETO LACARON Jul 21, 2008
    > Hi everybody!
    > > Hope someone has encountered a disaster that I
    > have with a Toshiba 42H81
    > blowing a 5A fuse.
    > > Sent to a home outside of Philadelphia with the
    > complaint "red light
    > blinks only". Found F850, F851 (5amp fuses),
    > F470 (2A) and F890 (3.15A) all
    > blown. Carefully checked for ANY defective parts
    > and found NONE (quite a
    > surprise when 4 fuses blow). I replaced all 4
    > fuses and held my breath..
    > TV immediately came on with a great picture which
    > really was a surprise!
    > Since there have been so many electrical storms
    > around I was hopeful.. 2
    > days later customer called and said "red light
    > blinks only". I expected to
    > find all the fuses blown again but only F850
    > (+16V) had blown. When I
    > replaced it the set immediately came on but I
    > "knew" there was no way it was
    > only a bad fuse. I pushed the service manual cd
    > in my laptop and found that
    > F850 and F851 both fed the 2 convergence IC's. I
    > replaced both and really
    > did not expect to hear from the customer again.
    > Surprise..2 more days and
    > "red light blinks only". I'm planning on driving
    > back tomorrow but I would
    > appreciate anyone's th
    > > oughts on this. Set cannot be removed from
    > home in this case so I will
    > certainly have to figure it out there.. I have
    > had some new bad
    > STK392-110's in the past but it seems unlikely
    > but any ideas are helpful!
  • LORETO LACARON
    The fuses are near around the convergence section.
    click below a picture guide sample of convergence STK..
    http://cmpalmer.blogspot.com/2006/11/fix...
    http://www.repairfaq.org/sam/tvfaq.htm#t...
    hope may this help;
    Good luck, and thank you in using Fixya;
    Scholar:
  • 191 Answers
Try doing a hard reset to the unit,,, unplug the unit for 3 hrs and then reconnect it back then tell me the status.
Posted on Jul 20, 2008
    Novelist:
  • 126 Answers
Hi there this monitor must give us a code variable there is an auto service directory if its the us model so press these buttons on the tv to enter blinking code hold a convergence down for 4 seconds while you strt up set the flashing led on the front of set will indicate fault code ok count the flashes then go online and google lct monitor fault codes and you will locate the problem its a good way to start
    Genius:
  • 1,665 Answers
Most LCD faults are of two types
1 Dead (Psu faults)
2 Display Panel Faults
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jul 20, 2008
    The Psu are Just like any Psu using SMPS (chopper), so use normal PSU fault finding techniques
    Start with , Any power from secondary of chopper transformer, at the diodes)
    usual PSU voltages are 5v,3.3v 12v (the 12v feeds the CCF tubes power generators)
    If yes the psu ok, If no check for 320v across mains smoothing capacitor.
    If 320v ok but no output, check for shorts on the output lines (schottly diodes)
    If the PSU is running and there are any leds glowing on the front
    check to see it the flurecent tubes (on each side) are glowing
    they usually have their own supply generators powered by 12v from PSU
    All faults that are within the panel aren't repairable (Specialist repairs are possible , But the COST)
    Master:
  • 726 Answers
I really think you have blown a fuse inside for the sound
  • chris07551 Jul 20, 2008
    well u have a power supply issue now u may have blown the power box inside
    Genius:
  • 1,011 Answers
Sir,
This is the problem of convergance. U must replace the convergance IC's then the problem is solved. Go to the authorized service centre for replace the convergance ic's.
Thanks
Don't forget to rate the solution
  • Asfiya Ahamed
    Asfiya Ahamed Jul 20, 2008
    Dear Sir,
    There are two main power supply capacitors in this set. they are C-809
    and C-810. One their negitive lead on the printed circuit boar, you
    may need to repair the area, and resolder that lead also. Because the
    factory left out a printed circuit board eyelet, the connection will
    come loose over time. Also be sure to check the fuse number F-860, as
    this will sometimes blow when these connection are bad. If you replace
    the fuse and the set works, you could be making a fire trap if you do
    not resolder these connections as they have caused some problems in the
    past, as this is why Toshiba has sent out a service bulliten on this
    problem. Now one thing for the both of you. If you do not have any
    solid stae repair experience, please play it safe and do not attempt to
    do this repair by yourself. Call in a pro to assist you as these
    capacitors may be floating from the printed circuit board and are fully
    charges up and can cause a seriuos shock to you. Bottom line? BE
    CAREFULL!!! Good luck and let us know how you made out with this
    repair.
    Thanks
    Good luck
    "Don't forget to rate the solution"
  • 2,322 Answers
The model you've provided is for a rear projection TV. The failure on Toshiba's rear projection TV is found most of the time in the convergence circuitry.
This ty
pe of repair is not a DIY, if you take the TV for repair it might cost you anywhere between $300.00 to $400.00
  • Jaime Hernandez Jul 20, 2008
    Can you check the specs on your TV and see if it's a LCD. I have the same model that is why I'm saying is a rear projection.
    Here's is the solution for you, replace the STK392-110 ICs and you will get the TV working again, you should know where locate them on the circuitry.
    Good Luck.
    Click here for more info on what could be causing the TV not to work. Download the first PDF file when you open the link.
    Brigadier General:
  • 3,614 Answers
Is there a light on the tv led, stating the it has a power... please add more info.
thanks
Hi,Iwas watching TV and the screen went black.No lights on,I unplugged and plugged again but anything happened. My TV is a Toshiba Regza model 42RV530U. Can you help me? Thanks
If there was a popping noise of any kind when the tv screen went black there's a high possibility that one of the fuses in the tv popped and there is no power to the tv. It could also just be the outlet itself and try plugging the tv to different working outlets.
May 24, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
I have a 46in. Samsung LCD TV. It worked lastnight now I tryed to turn it back on and all it does is the power light flashes and it make's a clicking sound can you help thank's very much.
The clicking noise indicates that its a power supply related issue. When the relay switches turn themselves off you will hear that sound. The first thing you should try is to unplug the set and hold for 5 minutes before plugging it back in and turning it on? Why? Because a power surge may have triggered these relays and unplugging them will reset them so that you can see if the set turns on. Otherwise we will proceed accordingly and troubleshoot the components provided you can follow a schematic.
Sai.
Mar 23, 2010 | Samsung 46IN LCD 1200:1 460DX BLACK 8MS...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Power light blinking
I have a Toshiba 42H81 that has the power indicator light blinking and the TV will not turn on
Oct 14, 2008 | Toshiba 42H81 42" Rear Projection...
TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
No power
Replace Convergence IC's STK392-110 and any burnt resistors
& check fuses F851,852,853,etc.........................T
Aug 11, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 42h81
have you try to switch it on using the contol on the tv..?
Jul 20, 2008 | Televison & Video
Toshiba 42H81 problem set won't turn on
This repair is for technical skilled only.....
1) Pull chassis
2)Replace open fuse(s)
3)Replace Convergence IC"s
4)Solder specific bad connects
5)Reassemble,test
Please read my previous posts concerning convergence repairs.
Or provide Make,model,age and symptom.............T.
Jan 03, 2008 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
188 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
