Blower motor vibration in a/c unit
My Carrier a/c unit is vibrating enough to shake the house. I replaced the motor and it made no difference. How can I check if the wheel is in/out of balance? What else can cause this?
There are thin weights that can be added to the fan blades much like you can add weights to a ceiling fan blade and balance it out. Real simple!
Posted on Aug 29, 2012
  • 143 Answers
You already checked to see if the blower wheel is out of balance by noticing that the a/c unit vibrates. There is nothing else that can vibrate that badly.
Go buy a new blower wheel.
Posted on Jul 22, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 5 Answers
You really cant check for it out of balance. not to mention you will never get it back into balance. The best thing to do is to buy another blower. the vibration will cause other problems including causing freon leaks in the evaporator coil.
  • JTran Jul 29, 2013
    Remove the whole blower unit out and place on a flat surface with the wheel face up; then use the small fan to blow air to the fins. While the wheel and shaft rotating, you can see the wheel out of balance, the faster the more vibration. To re-balance the wheel, you need to place a small tab on the fins at certain location and weight. It requires your skills and time. Noise is just one of its problems. Running out of balance for a long run will damage the bearing of the motor too.
Replace rear bushing in 2001 Malibu
First change the wheel/tire with the spare or another wheel tire to check for any change in shake.If the shake is in the seat it is usually in the rear,if it's in the steering wheel,then the front.
If the wheels are balanced all bushing could be loose and it will still be a smooth "no shake" ride.
Don't forget if brake discs and brake drums are out of balance no amount of tire balancing will correct a shake.
Also there is static and dynamic wheel balancing machines.You always want a motorized "dynamic" wheel balance done.
Sep 28, 2017 | 2001 Chevrolet Malibu
1. vehicle vibrates while braking @ speed of 55mph+ 2. automatic window does not operate correctly
Hello: 1. You may have rotors that are not parallel, if you can fell the brake pedal trying to move up and down while you have the vibration then you need to get the rotors turned and also check the front pads while its apart. If the brake pedal is not moving when you have the vibration or the steering wheel is not shaking then it could be the back rotors (if you have 4 wheel disc brakes). If its the driver window that does not go down automatically you may have a bad switch.
Oct 04, 2010 | 1998 Buick Century
My 1997 dodge grand caravanshokes really bad when
If it's related only to acceleration I would suspect a broken motor mount. The engine turns the wheels but there is an opposite reaction that tries to turn the engine over. It's held in place by rubber mounts that wear and can break. If the engine moves enough then the drive shafts are out of alignment and they can cause vibration. A bad CV joint can also cause this problem but usually causes different symptoms if you are turning right or left.
Feb 10, 2010 | Dodge Caravan Cars & Trucks
Furnace blower motor vibration
Check for a loose set screw on the motor shaft for the blower wheel.
Check the blower wheel for a missing balance weight.
Check the blower wheel for a dust buildup in the blades.
Check the blower wheel for a broken fin blade.
Check the blower motor shaft for excessive play.(more than 1/4 inch of play).
Check mounting screws on the blower housing.
Jan 04, 2010 | Ruud Heating & Cooling
2001 explorer sport trac, shakes bad when braking(like a bad rotor) inspected and everything looks new, checked runout on rotor with indicator and they look good, no real vibration when driving and dont...
does the shake come and go at different speeds? check your tie rod ends by lifting the front wheels off the ground and grab the tire and shake from left to right. if they are tight you probbably need to replace the rotors
Nov 17, 2009 | 2001 Ford Explorer Sport Trac
The ac unite has a lot vibration we just intall a new wheel blower
Wheel loose, out of balance (weight may of been knocked off during repair), loose/cracked mount/bolt(s). Take the motor/wheel assy. to where you got the wheel, they should check for balance.
Sep 17, 2009 | Carrier Heating & Cooling
My 1994 toyota camry has the shakes
most likey the tires need to be balanced
Mar 31, 2009 | 1994 Toyota Camry
Ford super duty vibration/shake
The carrier bearing should not move at all. It is mounted in rubber to give a little. But, it should not move freely. If this is the case then something has gone bad. The carrier bearing would cause this vibration as it spins if it is loose.
Mar 16, 2009 | 2002 Ford F250 Super Duty SuperCab
York P3HU Gas Furnace Blower wheel makes noise and vibrates
yes you have a bad blower wheel the fins are crimped to the disks, if you can take the blower assembly out just watch the wiring and take the motor out of the center of housing away from blower wheel and when taking out the wheel remember the diriction of the wheel
Dec 11, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
2,446 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
