Question about Kitchen Ranges
Diplomat Select 620 Our guests in France cannot cancel the timer and therefore cannot switch the oven off.
  • Anonymous Mar 24, 2014
    power is going to it
    President:
  • 1,462 Answers
This is nonsense on part of your guests. if thermostat is turned to off position, then oven will stop irrespective of the timer setting. suspect they may be listening to the casing fan which can run for some time after the oven is off
Posted on Jul 20, 2008
Diplomat Select 620. Put in new hinges but oven door still not closing properly. Any suggestions?
It may be due to some technical problem. You may can have help from the authorized help centers. That is good. Self prescription too bad and worst.
Aug 04, 2016 | Ovens
How do I grill on Diplomat select 620 oven?
Your question doesn't make sense?
Do you mean how to "grill" cook? or repair the grilling part of it?
May 19, 2014 | Lands Phones
How do you reset the clock on a Diplomat HJA 3300 oven? Would you by any chance have a pdf of the manual?
Press and hold the timer and casserole symbol buttons at the same time then press or - to set the time. If "auto" flashes you will have to cancel that programme.
Feb 25, 2011 | Ovens
I have a diplomat double oven no instruction or model no the bottom oven will not turn on and i can not get timer to cancel also an a is flashing on top left hand side of clock can you help ?
Sounds like the flashing 'a' means the timer is in automatic mode. I trust that when you turn the bottom oven to on the oven indicator light does not come on. Turn the bottom oven to ON. Then
have a fiddle with the timer. You have to get it to manuel mode. When it goes on to manuel mode the oven indicator light will come on and the oven will then work.
Feb 05, 2011 | Ovens
Diplomat select 620 fan failure
You should have no problem getting a replacement fan motor.
You will have to gain access to thr rear of the oven to change it, but it is usually a straightforward repair.
Please rate my solution.
Thanks.
Nov 17, 2009 | Ovens
Operating Manual
broiler will not cut off
Jun 25, 2008 | Ovens
Diplomat Select 620 single oven and no instructions
how do i remove the door to reseal the glass
May 14, 2008 | Ovens
Manual for a Diplomat Select 620 single oven
Sent the manual to you Tuesday the 18th.
Mar 09, 2008 | Ovens
Kitchen Ranges Logo
115 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
