Hp psc1410;AC power supply working, but no power going to printer. it will not turn on,even.. is there a "circuit breaker", or fuse, in this thing that i don't know about/or where it is??
    Guru:
  • 1,342 Answers
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Remove USP printer, check for a reset button on back of Computer, push it, push power switch, and see if computer comes back on. USB printer cable probably shorted, don't plug it in again.
Thanks
Good Luck
Don't forget to rate the solution
Posted on Jul 20, 2008
  • 19,396 Answers
The fuse is in power adapter. Printer has only micro fuses soldered on the board.
You need to replace printer pcb board.
1989 damon escaper ultrasport, at full hookup site A/C working fine until it just shut off. At that moment I was programming fridge because it wasn't cooling. Might be irrevelant but fridge now...
Your AC (air conditioner) would only run on AC (alternating current - shore power) so there would be a circuit breaker. Fuses are for DC (direct current - batteries).
That said, 16A is a very odd number for a circuit breaker (or fuse).
Your AC will only run if you are connected to shore power or have a generator. (Very large inverter and a lot of house batteries is technically possible but very unlikely and it wouldn't have been built that way).
If your AC actually draws 16A then being connected to a 30A outlet is fine, I have actually connected mine to a 20A outlet at home to test it but I made sure nothing else was turned on fridge, heaters, water heater etc).
May 20, 2017 | RVs
Laserjet 2300d will not power up. Is there a fuse or circuit breaker on the power supply? How do I access the Power Supply?
first check the power cord and source.. if you have a spare cord, switch them, if this does not work turn on the printer and listen closely for any sounds, like a humming , if there is not sound then there is a fuse on the power supply, you can pull it and replace.
and if that does not solve the problem time to replace the power supply board.
Aug 23, 2010 | HP LaserJet 2300d Printer
Sunroof will not work
Power is supplied to the Power windows and sunroof through the power window circuit breaker. That circuit breaker is supplied power through the RAP (retained accessory power) Relay, the RAP relay also supplies power to the radio. The RAP relay is also fuse protected by the RAP fuse in the under hood fuse block. The RAP relay is energized by the BCM body control module.
The RAP relay is responsible for the radio and windows working after the igntion is turned off.
The first place to check would be the RAP fuse in the under hood fuse block and then the RAP relay in the Body fuse block.
A list of the BODY relay block located on the left side of the dash to the right of the interior fuse block is below:
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay(1) Park Lamp Relay
(7) Door Lock Relay
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay
Jul 10, 2010 | 2000 Chevrolet Blazer
XEROX WORKCENTRE XD100. Machine will not turn on. Is there a fuse or circuit breaker and where is it?
No circuit breaker just a fuse in the power supply. Try wiggling the power cord in the back. If you can get it to come on it means the "block" that the cord plugs into is broken loose and needs to be re-soldered. If this does not work then you are going to need a power supply repair.
Mar 26, 2010 | Office Equipment & Supplies
HP Deskjet 9800 will not power up. Tried replacing power cord and tried plugging into a different power outlet. The little green light on the back of the power supply unit comes on, but the printer will...
Is there power coming out from the supply end
Is is a DC or and AC output supply?
If is it an AC output supply tyhebm in the back of the HP had an AC to DC converted that is realy a diode bridge and should contain a fuse in the circuit somewhere on that board
Jul 27, 2009 | HP DeskJet 9800 InkJet Printer
HP 7410 will not boot up.s
if the circuit breaker is not tripped on your surrge protector...unplug the power cord from the back of the printer...(not the wall plug, but where the cord goes into the printer) for at least 30 secs...that should reset your power supply
Jun 21, 2009 | HP OfficeJet 7410 All-In-One InkJet...
PSC1410 is stuck "ON" not communicating with the computer
it means your printer have problem his electronics circuit it may be dry soldring problem and also dust problem .
Apr 23, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP 2100 LaserJet, was functioning ok, now won't power up, power to AC plug is ok ... Is there a fuse somewhere ? Jim
Remove rear cover and fuser.
Blown fuses usually point to a bad power supply which is the circuit board under the fuser.
Feb 07, 2009 | HP LaserJet 2100 Printer
My hp psc1410 printer
yes by using windows gallery.open the windows gallery then click file - click import scanner - then select your printer model.scan it
Jul 18, 2008 | HP PSC1410 Printer
Model "KOT-152UW" The
well inside the unit check for any burn fuses on the power supply area, and into the control board. fuse basically the one will tripped if power surged occurred..
Jun 27, 2008 | Microwave Ovens
44 people viewed this question
jasbo
jasbo
