The shutter button is missing on the camera. The zoom switch is still there and functioning properly. Does the whole top cover need to be replaced or just the zoom switch shutter button and how do I remove it for replacement?
I have this issue right now. Please let me know what resolution you have found that is cost effective.
Same Problem
May 09, 2009
-   same thing happened to my 620... did anyone ever find a button? (toothpick worked great by the way... but hopefully there's a button available...) -   mikehmcclung
Jan 11, 2009
-   I have the same problem. My 18 month old dropped my camera and the button fell out. The camera still seems to work fine. I found the whole top assembly online as well, but I'm worried that I won't be able to install it myself. -   jsmith992
Jan 10, 2009
-   i dropped mine and i have the same problem. if you stick a toothpick in the little hole, the camera takes pictures. i just need the button..but all i could find is the top assembly with EVERYTHING for $35 or so.i might have to macgyver it somehow cause i really love this camera.
-   Guest
Popular Solutions for Canon PowerShot A620 Digital
My camera has a white speck of dirt underneath the first lens, and does interfere in pictures and...
(More)
My camera has a white speck of dirt underneath the first lens, and does interfere in pictures and videos. Is there a way to clean it out?
camera used in light rain, flash banged and quit, works otherwise is it possible to fix myself with...
(More)
camera used in light rain, flash banged and quit, works otherwise is it possible to fix myself with no particular qualifications
the date stamp is turned off and on the menu screen I cannot scroll down to the date stamp to check...
(More)
the date stamp is turned off and on the menu screen I cannot scroll down to the date stamp to check yes, it goes as far as grid lines and then back to the top
Hi, I know I had voided my warranty, but it has long been over anyway. I had open up the side of the...
(More)
Hi, I know I had voided my warranty, but it has long been over anyway. I had open up the side of the camera ( where the lcd screen is attached ) My screen first went grayish, as I put most of the srews back in the screen went black. The shutter works fine and I can take pictures take out the sd card and view on my computer. But I need the LCD screen to use for extreme close ups wich was working great. I have also noticed if screws are to tight a PSP screen would do the same. Can anyone tell me what I should do? -- My father told me once that if it's not broken dont fix it... Should have listened. Thanks to anyone that can help. Swede00
