2005 Subaru Forester Logo
Posted on Feb 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 2005 subaru forester. my engine shakes all the time especially when it is idle. when driving i dont feel the shake but when i stop it shakes. i have replaced my plugs but still shakes. also when i accelerate hard or driving at a speed of about 80mph i smell something like rotten egg smell even if i hv rolled all the windows. No check engine like too. it only comes on after i turn on the key but goes after i spark it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 14, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1347
Points
It helps to let the engine idle for a minute or two. Then while it is idling if the fans turn on, wait until the fan shuts off, then turn off your car. Also you must let the engine warm up before driving away in it. If you do these things your engine will not shake on you anymore.
Anonymous
Level 3:
  • Master 1,874 Answers
  • Posted on Feb 01, 2011
Anonymous
Master
Level 3:
Answers
1874
Questions
0
Helped
2165473
Points
7058
First step is to access the Engine Control Module (ECM) using diagnostic equipment connected to the data link connector of the car, in order to pull out all Diagnostic Trouble Codes (DTC) memored. Even if engine Malfunction Indicator Lamp (MIL) goes off after engine starting, it's possible to find out temporary DTC codes memored in the ECM. Then you will be full informed about bad components (e.g. bad heated oxygen sensor(s), cylinder(s) misfire(s), bad injector(s), bad ignition coil(s), ... etc). Therefore you will be able to repair & replace bad components and reset the ECM.
In the most cases when you smell something like rotten egg there are bad oxygen sensor(s).
My lincoln navigator shaking? i have changed coils and fuel injectors but still i have the same problem? please help?
Is your check engine light on? Does the engine run smooth when in gear end just idleing? If the engine has a miss to it while idleing, Does the vehicle loose power as you accelarate? Depening on the mileledge on the vehilce if it isn,t a high mileledge vehicle ,End was not (Abuse) It probally needs a good majour tune up. Change the spark plugs end (Wires)
1helpful
Cold start-extremely rough idle-Shakes,smell fuel
Black smoke means buring rich. Have the vehicle's ECU scanned for codes and do the repair the codes describe. I'm gonna take a stab in the dark and say Mass Air Flow Sensor.(MAF)
2helpful
2answers
2004 subaru forester, 99,000 miles. Check engine
First suggestion is go to AutoZone and get the error codes read (for free) -- this'll probably tell you exactly what the problem is.
Charlie
My 2003 subaru forester idle very rough. if you open the hood and look at the engine it is shaking like its firing on only three cylinders. I need some help.I changed the spark plugs, gas filter, air...
1) Check all the vacuum hoses for a leak in the rubber hose or a hose that isn't connected. Vacuum leaks cause motors to shake and stumble on acceleration.
2) There's a plastic T connection on the back side of the engine behind and under the air cleaner box. That T connector joins together three air hoses of different sizes and is prone to breaking from heat stress. Only a Subaru dealer will have this part.
3) Even though the spark plug wires are new, you may have a bad one. Don't waste your money on cheap parts; they cost more in the long run.
Top Subaru Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Subaru Expert? Answer questions, earn points and help others
