Question about Casio Watches
How do you replace the watch band on a casio g-shock
  • christopher spencer May 11, 2010
    Are you looking for a band. or just instructions on installing the band.
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Posted on Jul 23, 2008
Replacement bands for G304RL g-shock
Most stores that sell the watch also sell the bands. Or plug the model number into your search engine and buy one online. Spend time making sure it is the correct band as there are many different models and they are not interchangable.
Oct 08, 2012 | Casio G304RL 1A1V G Shock Street Rider...
I need a new band for casio g shock g-314rl. what size will fit.
mcdevito75 here, Ebay is your best bet for a new band for your Casio watch, simply type into serach, at ebay, Casio watch or watch bands and shop.
Nov 19, 2010 | Watches
Casio G-Shock GW-300 replacement bands
I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
This cost disturbs me.
Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G plastc watch case holder replacement source.
i need a replacement case for g shock gw-002e,any ides where i can get 1.im in essex,uk
Feb 25, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Watchband replacements?
On ebay you will be able to find the correct Casio band for your watch. There are 2 or 3 dealers that sell them but a little advice....don't buy the cheap ones! Buy ONLY the Casio replacement band and it will fit perfectly. You will need the spring bar tool to remove the pins that hold the band to the case. Don't try to install or remove the band without one....it will gouge the case at the pin stems and you will not be happy. They are cheap and worth every penny. Casio.com can also direct you to their watch bands. Hope this helps you and good luck!
Dec 11, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Broken wrist band
The easiest is to bring it to Wal-Mart, or another store with a watch section in their store, if you buy a new wrist band, they;ll put it on for free. If you're feeling DIY, pull the watch band to the side, untill the metal bar inside is ejected form the slot in the watch, from there, insert the new band's bar into the slot, and voila!
Nov 15, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Change casio g shock resin watch band
It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
make sure you keep all original parts in case of toruble
Post a photo if you can after the change will be nice to see the change
Tom
Nov 10, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Casio G Shock (Model G2300)
you have to remove the pins located under the band
Feb 26, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio g-shock 2900
Hi there
There is no contrast adjustment...
Batteries low can affect the contrast. Try replacing the batt first. Is it all black? If so, the LCD is damaged.
Feb 14, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
566 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
