Question about Samsung SyncMaster 753S 17" CRT Monitor
Thank you very much for showing concern in my problem. I recently noticed that the width cut from sides changes on changing refresh rate. also, screen gets shortened everytime i play games like counter strike. for eg., after playing game for 5-6 times and exiting the game screen size reduces by about 2 mm or so. About replacing the parts, i think i will get it by some technician but it would be handy if i know what is faulty or else the technician would charge a kings ransom by replacing everything.
    Brigadier General:
  • 6,966 Answers
Use the schematic diagram near the end of the service manual. Ask your tech to check the components around the C429, D409 and L401 area. Alternately, follow the trouble shooting chart of 5-1-6 and/or 5-1-7 of the same manual.
Posted on Jul 20, 2008
"Heat Waves" on Projector
what your seeing is the refresh rate of the projector to negate this go into the settings and change the refresh rate
Jan 09, 2014 | Office Equipment & Supplies
Screen Adjust
You can't. There are no adjustments for height and width. Not all programs were shot on 16 x 9 wide screen resolution so it will leave the screen with black spaces . around the edges. Nothing wrong with the TV, and nothing you can do other than the zoom buttons you use now.
Aug 09, 2017 | Sanyo DP19648 19 in. LCD TV
My compaq presario sr1620nx screen is shaking
Look for your computer's monitor settings, then adjust its refresh rate.
To modify a refresh rate on Windows, right-click anywhere on the Windows desktop.
Select "Properties," then choose the "Display Properties" tab on the window that appears.
Click the "Settings" option, then select "Advanced" from the window that appears.
Choose the "Monitor" tab, which lets you access a drop-down menu with the options for refresh settings adjustments.
As a basic guide, use a setting of at least 75 hertz.
Confirm the change by clicking "Apply." Reboot the PC to ensure the new settings on the screen take effect.
Check your screen if the blinking problem is resolved. If not, try a higher refresh setting.
If there is no change on the flickering of the screen, this means the problem is not caused by the screen's refresh rate.
If your computer is not running on a battery or surge protector, shut it down to safely transfer the plug to another outlet
Hope this helps.
Nov 27, 2012 | HP Compaq Presario SR1620NX...
Recently the font on my monitor has become a bit fuzzy, I've tried auto adjust, changing the resolution but they did not help. My motherboard and video card were recently replaced but the person who...
the refresh rate frequency should be 60hz, and monitor resolution 1024 x 768 , should work fine but if the the problem still it might be the lcd monitor getting OLD :) ,you can make sure by connecting the monitor to a different pc and notice the font.
Feb 26, 2010 | Rosewill R700J 17" Flat Panel LCD Monitor
Pixels aren't refreshing correctly in upper right hand side of screen
You might have a Service Co. come out and look at it. It sounds like the Z module is not doing it's job of erasing all prior images after a scene change. Some models there are adjustments for that internally. ( only for a tech ) Start a paper trail now.
Apr 28, 2009 | Televison & Video
My LCD monitor is blinking very frequent.
When the refresh rate changes then the screen will flicker. Change your refresh rate to above 75.
Here is how: Click on Start>Control Panel>Display>Settings>Advanced>Monitor>and you will see screen refresh rate. Change to higher rate.
Rate this solution.
Jan 09, 2009 | Acer Aspire 4315 Notebook
Dell m992 monitor screen width
The link below is a Digitally signed M992 monitor driver. http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R44148&formatcnt=1&libid=0&fileid=51992 Also try upgrading to the latest ATI software and drivers. You can also try and change the frequency refresh rate to 75mhz. It in the Control Panel under 'Display' and tab 'Monitor'. It shows a list for frequencies you can try.
Oct 02, 2007 | Dell M992 19" CRT Monitor
Likom Futura LDF770
There may wrong setting of refresh rate. Most monitors work at 60 to 70 Hz refresh rate. Above that they tunned blank screen or out 0f range message displayed. Also check the output video signal. Please confirm technical specifications from the documentatation of the monitor.
Aug 15, 2007 | Likom Futura LD7 17" CRT Monitor
OSD doesn't appear
You will find the number one motto from many of the Tech's is "If it ain't broke, don't fix it!!!" If you must fix it try the latest drivers for your video card and for the monitor. The OS(XP) is always changing. Keep the drivers up to date. Otherwise. Don't mess with it. Good Luck, Let me know what happens. Tim
Mar 06, 2007 | LG Flatron F700P 17" CRT Monitor
Syncmaster 710N resolution problem
no,
the LCD display don't harm the eyes cause don't spreed radiation.
preferred resolution 1280x1024 at refresh rate of 60Hz is not optimal.
the samsung 710N can easy handle 75Hz at 1280x1024 so just change it.
Jan 30, 2007 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Samsung SyncMaster 753S 17" CRT Monitor Logo
191 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
