Saeco magic deluxe espresso machine - dismantled frothining atttachment to clean. Now wont froth properly. Perhaps two small seals are in the wrong way?
Sounds like a board issue. It was something that happened on the Saeco Magic Deluxe's enough to be noticed. The board is not available for magic deluxe's with oval buttons.
Hi There is a donut like cap under the water tank on top of the machine. Pry on the outside of this cap an pop it off. Under the cap is a black seal. If you stick your finger in it and just pull out and the seal comes with it, you need to replace the seal. The new seal will not slip in you have to run your fingernail around the outside and silp the seal in. It should not just slide in. Make sure that the receptacle is clean before putting the new seal in.
I think you have a chrome steam wand end.
To froth properly, there is a very small hole on the side of the chrome steam wand that injects small bubbles into the milk, the hole is located aprox 1/4" down from top of the chrome wand, if this hole blocks up you can only heat the milk, not froth. I commonly use a stripped tin tie wire or a sewing needle to clear the hole . Clean the hole,do not enlargen the hole.
